Old 06-16-2022, 06:40 PM   #1
lightdisc2
Drives: Yaris 2008
Oil and Coolant Leak, Serpentine Belt fell off
Having a pretty unfortunate issue with my 08 Hatchback. I had my first partial synthetic oil change last service, about 6k miles ago. Car has 170k miles. I usually only do conventional and will be sticking with conventional for now on. I was told I could go 7k miles on this oil change. I was on the way to get an oil change, after my engine was making some weird noises like it was low on oil. When I get to the (drive-thru) oil change shop, they let me know there is oil and coolant leaking all over the right side of the engine compartment, and that my serpentine belt had fallen off.
I drove 5min to my mechanic (wouldn't go any further without towing it) and he is going to look at it tomorrow. Could this possibly be caused by waiting too long for an oil change, different kind of oil being used, or anything else? Could the leaks themself be caused simply by the serpentine belt failing (it did not snap, only slipped off; it was covered in oil and is about due to be replaced)? Also the coolant temperature light came on for the first time in that 5min drive to where the car is now. I am not mechanically inclined, but any idea on advice I should give to my mechanic?
Thanks
lightdisc2 is offline   Reply With Quote
Zage Turbo Kit Install - Toyota Yaris Focus_Sh1ft Forced Induction Forum 160 02-06-2022 09:14 PM
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 03:47 PM
Oil and coolant leak jaybowblue DIY / Maintenance / Service 1 08-14-2016 11:41 PM
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-14-2014 12:17 AM
Lost Serpentine Belt NickNickNick DIY / Maintenance / Service 33 07-31-2011 01:28 PM
