Old 03-04-2023, 09:51 AM   #1
bronsin
bronsin's Avatar
How long is a fuel filter good for?
The one on my wife’s 2005 Camry will be 19 years old in September and has 200,000 miles on it.
The belt that drives the water pump, Alternator, AC, and power steering went 150,000 miles.
Old 03-04-2023, 05:37 PM   #2
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150
I change mine on my truck once every couple years, its easy and cheap.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
Old 03-08-2023, 08:31 PM   #3
mirageman
Drives: 2009 yaris
I have 250k miles+ on my original fuel pump and filter. I recently took it out to see what kind of filter it used and I could blow right through it. I'm not going to rush to buy a new one, but I don't want to wait long.
mirageman is offline   Reply With Quote
Old 03-09-2023, 01:11 AM   #4
bronsin
bronsin's Avatar
I think they don’t sell new fuel filters buy them selves. They only come with the pump as far as I know.
Old 03-09-2023, 12:49 PM   #5
Neinris
Actually they do, you just have to make sure you get the correct one, because there are two different housing and pumps. There are other thread that covers this. This one is for the later model with the pump exit off centered.
https://www.ebay.com/itm/36394221977...&segname=11051
I have not done this, but it could be a PITA to swap, since you'd have to stretch the hose over the barbed nipple. But maybe with some patience and help with needle nose pliers it wouldn't be too difficult.
Most of the time if you're buying just the pump, it'd come with the strainer.
Old 03-09-2023, 01:24 AM   #6
sh0rtlife
unless your in a place that sells dirty fuel you should be fine indefinitely
Fuel Trim Readings and EGR valve tmontague DIY / Maintenance / Service 1 01-22-2015 01:28 PM
HELP: Swings but does not start after fuel filter replaced REV 2 11 DIY / Maintenance / Service 12 08-19-2013 02:38 PM
Fuel filter or Fuel pump :( tyrone_yaris DIY / Maintenance / Service 2 05-08-2012 02:32 AM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 04:34 AM
Fuel Filter abbeyaris General Yaris / Vitz Discussion 35 03-22-2009 12:40 PM
