Old 03-11-2023, 06:42 PM   #1
Binks
Drives: 2006 Yaris
Trying to figure out new wheels
Hey y'all.
I got a 06 5dr hatch lowered on this bilstein kit.
https://t1motorsports.ca/products/bi...suspension-kit
Been hummin and hawing about new wheels. Worried about rubbing but I think I'm being too cautious. Would a 15x6.5 +35 offset with maybe a 195/55r15 on it be safe? Mostly concerned about the poke.
Here's some pics how it's sitting in the front on 175/65r14x5.5 +46. Thanks!
Binks is offline   Reply With Quote
Old 03-11-2023, 11:59 PM   #2
remcafee
flush fitment would be 16x7 +35, so your 6.5 would be tucked in
Old 03-13-2023, 04:18 AM   #3
Compeer
Drives: NCP90 TRD Yaris Manual
I run r15195/50 with et32 rubs a tiny bit iner guard when parking as I think I need a 3mm spacer bbut otherwise love em.
Compeer is offline   Reply With Quote
Old 03-13-2023, 01:25 PM   #4
Neinris
Hmmm... So I guess the 16X8 +30 wheels that I want to put might not work without having to put spacers. I was thinking of marrying them with 215/45 R16s, which should make them flushed with the wheels (depending on tire brand). This video features 215/50 tires on 17X8, not the same profile and diameter, but the same width wheel and tire.
https://www.youtube.com/watch?v=XieYsLZgYjY
Old 03-13-2023, 02:47 PM   #5
sh0rtlife
i run 195/50/14s no issue, my snow tires are 205 50 15 on XB wheels which is a tad more offset than stock and no rub from either
imo if you get good tires you dont need to go wider than a 195 or 205 anything wider is just going to hurt the fact that youve got little torque to work with in the first place...and try and stick with light wheels
Old 03-13-2023, 03:57 PM   #6
Neinris
I wanted to go 5X114.3 PCD to put the R32 GTR wheels (16X8 et+30), but I think I'd just go with some CP22 still 5X114.3 PCD, but they're 16X7 et+35. Yeah they have them in 4X100, but they just don't look right.
Old 03-16-2023, 02:26 PM   #7
Binks
Drives: 2006 Yaris
Ended up biting the bullet and got some avid1 av-08s with 195/55r15 yokohama advan flevas! Very Excited to see how it looks, thanks guys.
Gonna be a bit taller of a setup but I dont think it should rub and I got some camber bolts that should make it safe.
Old 03-17-2023, 11:11 AM   #8
Neinris
How accurate is your speedometer with the 175/65 R14 tires?
I was going to say don't worry too much with the 195/55R15 tires being a bit taller. One of the OEM wheel/tire combo is 185/60R15, which is taller than what you picked, but would make you go faster (about 2MPH) than what's indicated by your speedometer if your speedometer is dialed for 175/65R14.
Old 03-17-2023, 11:58 AM   #9
Binks
Drives: 2006 Yaris
Seems pretty accurate but I haven't done anything to tell other than read my speed on those speed warning readouts.
Thanks! I'm not too fussy about that kinda stuff
Old 03-18-2023, 02:49 PM   #10
sh0rtlife
there is always a bit of "wiggle" in a speedo acuracy to make up for slight changes in tire size so dont stress it....mine came with the stock tall skinny 14s..terrifying tires lol
having worked tires for a good while...i can tell you that +/- 1 inch of tire is small enough to not even notice a change in speedo..and in alot of cases 2 inches is still within spec, once you get outside that you WILL see changes...as those changes are more noticed at speeds above 60mph
Old 03-18-2023, 03:03 PM   #11
Neinris
My car is dialed for the 175/65R14 tires, and I have 185/60R15 tires, which makes my speedometer inaccurate, I'm actually going 62MPH when me speedo is reading 60MPH. I bought a different speed sensor gear, which is supposedly for the bigger tires, but it's a PITA to get off the transmission.
I got a HUD from my Brother-in-law for Christmas, and I'm happy with it, because now I have a tachometer as well as an accurate speedo.
Old 03-19-2023, 03:34 PM   #12
sh0rtlife
i feel like the "tach equiped" dashes stay more acurate with tire changes somehow....you need to swap your dash!!!
Old 03-20-2023, 03:38 PM   #13
Neinris
I was looking for one from U.K., since they use MPH, but it's sold out now...
Old 03-20-2023, 10:30 PM   #14
sh0rtlife
look to canada..they read both MPH and KMH...tho KMH is the "dominant" outer line...youll learn to live with it eventualy
FS: Mini Cooper 5 Spoke Wheels with Tires, Hubcentric Rings and Lug Nuts CTScott Items for Sale by private party 14 08-18-2012 12:18 AM
FS: 15x7" Advan Kreuzer xii Wheels - New - Various - Cheap jtf1986 Items for Sale by private party 21 08-15-2011 03:30 PM
JDM Wheels and some track wheels/tires jdmekcivic Items for Sale by private party 10 09-08-2009 01:27 PM
forged rims Vs. alloys red-jdm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 07-23-2007 09:30 PM
