Old 10-05-2023, 11:19 AM   #1
1st Toyota
Drives: Yaris 2nd Generation
Yaris 2 Front Wiper Arm Removal
Wiper arm doesn't come off after removing nut. Plastic surround is so close, unable to fit a puller. Any ideas please?
1st Toyota is offline   Reply With Quote
Old 10-06-2023, 01:10 AM   #2
komichal
Did you spray some penetrant into it? There is no magic in there as far as I know.
Old 10-06-2023, 03:37 PM   #3
1st Toyota
Yes, sprayed WD40.
Unbelievable there is nothing in the search engines for removing the wiper arms on a Yaris 2.
Old 10-06-2023, 03:51 PM   #4
You need to use a better penetrating fluid than WD40. Apply 3 or so times a day for a couple consecutive days. Rock/wiggle the arm periodically during application period and it should eventually break free.
Old 10-09-2023, 06:07 PM   #5
sh0rtlife
WD40 is NOT an oil, its not even a penetrate of any kind...in all fairness to WD40 its not ment to lube anything WD stands for "water dryer"
if your cheep and want to wait..get some pb blaster..its not bad stuff but its not great...if you want "quality" order up some "kroil"
as far as removal goes, with the arm vertical pull up on the bolt side while slightly pushing down on the arm side..this useualy will break it free
Old 10-11-2023, 12:25 PM   #6
thetut
Drives: 2007 4dr sedan
WD40 does make a penetrating spray: https://www.wd40.com/products/penetrating-oil/
thetut is offline   Reply With Quote
Old 10-11-2023, 08:21 PM   #7
ex-x-fire
This is what I'd try. https://www.amazon.com/Advanced-Adju.../dp/B07WRYCH24
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 09:47 AM
Do you like the 2012 restyle? hitmoninfinity Third Gen Yaris General Discussion 106 04-14-2016 09:08 PM
P1 rear wiper arm on P2 Chariz Cosmetic Modifications (Exterior/Interior) 1 10-12-2014 07:08 PM
