Old 05-14-2019, 10:37 PM   #1
seatech30
Drives: Yaris 2008 Sedan
Motor mount bolts torque specs? AT, back "dog bone"
I'm planning to swap out all my motor mounts. I'm missing torque specs for two bolt types on the bottom/back mounts. See image in red. Part numbers are 90119-14139 and 90105-10301 if that helps. Thanks!
Side question, from my understanding of the documentation, it seems to be best to replace mounts in the following order, remove pass side, remove transmission side, replace transmission side, replace pass side, remove back/bottom, replace back/bottom. Is this about right?
seatech30 is offline   Reply With Quote
Old 05-15-2019, 01:29 AM   #2
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
90105-10301 - 29 ft-lbs
Can't seem to find torque spec for 90119-14139, sorry.
Old 05-15-2019, 02:02 AM   #3
seatech30
Thanks for the spec! One more down, so no worries. I may have to go by feel based on the size of the bolt once I get it out. I'll report back if I find any way to get a good estimate.
Old 05-15-2019, 10:05 AM   #4
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I may have that page of the repair manual at home (buried in the garage). I'll see what I can find...
Old 05-15-2019, 09:16 PM   #5
CrankyOldMan
100 Nm, 74 ft-lb. Same for AT and MT.
Old 05-16-2019, 01:43 AM   #6
seatech30
:O I need to get me one of those! Thanks a bunch!
Old 05-16-2019, 02:21 PM   #7
CrankyOldMan
I don't have a full book, just excerpts from when I had a TechInfo subscription. I'm not sure if that's even a thing for the Yaris...
Old 05-16-2019, 02:53 PM   #8
NYC-SE
NYC-SE's Avatar
There was a post somewhere on here that had a link to a pdf Yaris manual. That's how I got mine. I'll see if I can find the link again.
Old 05-16-2019, 03:01 PM   #9
NYC-SE
NYC-SE's Avatar
Found it:
http://jdmfsm.info/Auto/Japan/Toyota...als/index.html
Also:
https://cardiagn.com/2007-toyota-yar...r-manuals-pdf/
I was able to download the first link. The second link would let me view online but not download. FYI even though this is a manual for a second generation car most info is applicable to 3rd gen as well.
Old 05-17-2019, 11:27 AM   #10
seatech30
Found it:
Also:
Thanks for the link, I actually have these manuals from a while back, unfortunately they don't show all the torques for every aspect of car jobs, in my case replacing all the mounts. I went through all engine related ones and couldn't find the two torques needed.
However, I did find a spec sheet that shows you how to determine the torque for all bolts based on their size and pitch, so I'll be using that in the future for any other mystery bolts.
Edit:
Originally Posted by toyotavios_11 View Post
are you getting Ori mounts or OEM mounts?
I went with the following parts DEA A4254, Westar EM-5930, DEA A4237, and 12364-21020 from Toyotapartsdeal which I believe is supposed to be OEM. I just wasn't ready to drop OEM money for something that many not be a sure fix. Had this issue with my old yaris and did all mounts twice with OEM from tpd and it never was resolved. If I see a difference, I'll fork the money when these go out. I haven't heard or seen Ori. I'll check them out, thanks!
Edit2: while putting my back seats frame bar back on, I realized the bolts used had a torque spec of 125Nm on the doc I mentioned, after some testing, I determined that those bolts were actually 42Nm (same as the seat belt bolts.) Just thought I'd mention it in case someone else makes the same assumption I did.
Old 10-05-2023, 11:17 PM   #11
satannuts
Drives: Toyota Yars
Originally Posted by seatech30 View Post
Edit2: Went with 50ft-lbf. Tried to go for 74ft-lbf, but felt like too much, didn't get there.
I did a trial on removing the ENGINE MOVING CONTROL ROD BRACKET and it seems the bottom of the top two bolts is going to give me a hard time. I'm guessing I can jack the transmission up? Will loosening be necessary on the other mounts or is there anything else I should watch for?
Hey, did you ever get that hard to reach bolt out?
I just tried to change this lower engine moving control rod and bracket, but I couldn't get to that one hard to reach bolt.
satannuts is offline   Reply With Quote
Old 05-17-2019, 03:45 AM   #12
toyotavios_11
Drives: Toyota Vios
toyotavios_11 is offline   Reply With Quote
Old 05-19-2019, 07:43 PM   #13
seatech30
CrankyOldMan, just realized what techinfo is. I thought it was something for mechanics. I got the 2 day subscription, waiting for it to let me in. I think it wont take effect till midnight, though. [Scratch that, I got in, had to change password for some reason] Thanks!
I took off the engine RH side mount because it arrived first, but it didn't come with the bracket. I took it off the old one, it was on there good. But the repair manuals don't show the torque for this bolt (dead center under the mount cylinder.)
[I can't seem to find the section that you showed in your pick. Most of what I'm seeing is like what I already have.]
Old 05-20-2019, 09:51 AM   #14
CrankyOldMan
I'd have to see a picture to know for sure which one you need, but that would probably have your answer in it. =)
Old 05-20-2019, 12:55 PM   #15
seatech30
This is the one. I think I saw somewhere that mounts only last about 30-50k miles lol hmm.
Edit: I emailed the manufacturer, and they told me "30Nm ( 22 ft.lb )" somehow I don't think that's enough. I'll leave them at 50ft-lbf for now.
Old 05-21-2019, 08:54 AM   #16
CrankyOldMan
The stud that's poking out from the one on the right? I don't recognize that mount, but I don't think that the AT and MT have different parts. It's been a hot minute since I've looked at the 1.5 L mounts. What size bolt/thread is it?
I highly doubt that the Toyota spec for mounts is 50k miles. That's pretty crappy even by US domestic manufacturer standards.
Old 05-22-2019, 02:32 AM   #17
seatech30
No, I have the spec, 38ft-lbf, for the nut that goes on that stud. I'm talking about the bolt in the center. The mount is upside down, so that's probably why it looks off. Notice the bracket missing from the other mount. I just swapped that over to the new one. Went with 50 ft-lbf. Thought about doing 74ft-lbf but felt a bit too much while trying to get it there. Thanks for the help anyways.
Old 05-23-2019, 09:33 AM   #18
CrankyOldMan
The bolt in the center shouldn't ever be removed, as far as I know. That's the one through the damper/rubber part, right?
Torque Specs 2009 Suspension GrayYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 04-23-2014 12:04 AM
looking for torque specs on front caliper bolts 07 yaris mikee07 DIY / Maintenance / Service 2 10-21-2012 04:36 PM
torque for wheel bolts? caineroad Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 05-13-2012 09:07 PM
Suspension Torque Specs pls nisyota Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 12-21-2010 08:04 AM
Tighten bolts to factory specs? marlondog Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 10-19-2010 06:18 PM
