![]() Drives: 2008 Toyota Yaris Hatchback MT Join Date: Feb 2024
1ZZ Throttle Body Upgrade
I just got the 1ZZ throttle body from a 2005 Corolla. Part# 22030 - 0D030
It takes 4 bolts and has 2 angled hose hookups. Do I need to swap over the black plastic rivet part of my stock throttle body onto the 1ZZ? I have a 2008 Yaris hatchback 1.5L manual. |
Gen 3 > Gen 2
Drives: NCP131, F-150 Join Date: Jul 2019
You don't HAVE to but some users have reported drivability issues when doing this mod that is usually fixed by swapping boards. YMMV.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2013 Rav4 LE AWD Autotragic - Wife's
Okay thanks
![]() ![]() ![]() Drives: NCP90 TRD Yaris Manual Join Date: Oct 2022
You will need to swap the black pastic board riveted on yes, otherwise it will throw error codes and ether not drive at all or put you in limp mode. Its an easy swap drill out rivets and swap then bolt or revite back together. You will also need to adjust the idle with the little hex screw hidden under the yellow glue.
| 1zz throttle body +what intake?? | 0BD1Kenobi | Performance Modifications | 17 | 10-21-2019 08:45 AM |
| 1zz Throttle Body Question | rabbito | Performance Modifications | 5 | 12-09-2015 12:09 AM |
| [Buy] throttle body 1zz yaris 1800cc to 1500cc TS | Nets | Items for Sale by private party | 2 | 04-25-2010 11:27 AM |
| 1ZZ throttle body | aucorium | Performance Modifications | 44 | 03-14-2010 01:57 AM |
| 1ZZ-FE throttle body | crxgames | Items for Sale by private party | 1 | 04-27-2009 06:19 PM |
