Old 03-16-2010, 03:38 PM   #1
DIY - How to remove or insert a pin on the ECM Connector A21
This DIY is primarily for those needing to know how to add the pin to position 40 of the ECM connector A21 for the DIY cruise control on 2006-2008 Yaris.
Note: It is always a good idea to disconnect the battery when working with the ECM wiring.
A. Release the ECM Connector.
1. Push the release button on the end of the connector latch with your fingertip. You will feel a slight click and will then be able to lift the arm:
2. Lift the latch arm from horizontal to vertical. It will move easily at first, then will require a bit more force as you near the vertical position:
3. As the latch arm nears the vertical position, the connector will lift slightly off of the ECM:
4. You can now remove the connector to work on it. To obtain full access to the pins, carefully snip the cable tie from the rubber wire protector and remove it.
B. Remove a plug
1. To remove a sealing plug, insert a stiff wire (paper clip, sewing needle, etc.) into the hole on the ECM side of the connector.Pin 40 - Plug still in.jpg
2. Push the object and the plug will begin to push out of the wire side of the connector.
3. Once the plug is out, you are ready to insert a terminal in its place,
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 03:12 PM
Wires Inside the Yaris & What They Do The Architect DIY / Maintenance / Service 149 10-18-2022 04:32 AM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 01:59 PM
Viper Alarm Install gwasabi In Car Entertainment + Electronics (audio / video / alarm) 28 08-11-2010 03:57 PM
