Old 08-21-2024, 12:17 AM   #1
IndestructibleYaris
Hub Removal for Wheel Bearing or ABS Sensor - The Easy Way
Take a bolt and nut. Push the bolt through a hole in the hub and thread a nut on the other side. Jack the hub off the backing plate and axle/knuckle.
https://youtu.be/kxB9xCZ-w5Q?si=383D_-3WqNW-aeUW
IndestructibleYaris is offline   Reply With Quote
Old 08-29-2024, 06:26 AM   #2
Billiam
Drives: '10 White Yaris 4D LB
This is the process I used to remove the bearings when I had to replace my rear beam. It works.
If you want to enjoy your car, stay off of the internet.
Old 09-05-2024, 06:49 PM   #3
IndestructibleYaris
This is also for doing rear ABS/wheel speed/skid sensors which are lightly pressed on the back of the hub bearing, and they require the hub to be completely removed first.
yaris hub and bearing assy with abs chrissy b Items for Sale by private party 8 12-12-2011 10:22 AM
for sale yaris and yaris verso hub and bearing assy chrissy b Items for Sale by private party 0 04-07-2010 07:52 PM
for sale yaris hub and bearing assy all models chrissy b Items for Sale by private party 0 03-31-2010 09:21 AM
for sale yaris hub and bearing assy all models chrissy b UK 0 03-26-2010 10:56 AM
