Old 06-06-2025, 10:37 PM   #1
Greenyaris2007
Drives: 2007 yaris
Coolant lead from floorboard behind drivers seat
2007 Yaris 4 door - Amazing car. Want to keep it going forever. Stumped on a coolant leak and wondering if anyone here has had the same issue?
220k miles - rust belt car. Coolant system all original other then water pumps and fluid.
First hot day in NJ this season and the car stalled at a traffic light. Coolant light flashing and check engine. Was able to get the car restarted and pulled off quickly so that I was not in an accident. Let the car sit in a lot for hours while it cooled off.
It took a gallon of coolant to get it to the top of the fill cap. Car started and made it home 2 miles. Went outside a little after to see where the coolant was leaking from. Found coolant at a constant fast drip coming from a floorboard body hole behind the driver side seat (on the undercarriage). Engine bay is pretty dry although there was some wet spots under the waterpump.
Engine oil checks out clean - no coolant mix.
Is this a heater core? Carpets are dry. No coolant smell inside the car.
Any help is greatly appreciated.
Greenyaris2007 is offline   Reply With Quote
DIY - Sparco Race Seat Install Idjiit DIY / Maintenance / Service 16 08-14-2017 10:15 PM
I have rip/tear on drivers seat going on. Killchain Cosmetic Modifications (Exterior/Interior) 2 09-10-2015 03:53 PM
Back Seat Removal... Idjiit DIY / Maintenance / Service 87 02-08-2015 01:07 PM
Drivers Side Seat Belt Won't Retract redyaris DIY / Maintenance / Service 8 08-07-2014 11:37 AM
Fabric Wear On Driver's Seat Darth Gilbert General Yaris / Vitz Discussion 18 04-28-2007 08:13 AM
