![]() ![]() ![]() ![]() Drives: 2009 Meteorite 3dr Join Date: Jul 2009
Idea I had, but I can't figure a way to make it work...
Can anyone think of a way to make my idea work???
My idea was to remove the passenger seat and install a swiveling mount for my laptop there so the driver or rear passengers could control the laptop, and it could be plugged into the accessory input for music (watch music videos or DVD's on it as well, etc.) I tried to remove the passenger seat, and it was not happening, I made no head-way on it. if there is some secret to getting the bolts loose or something then maybe I can still install something there. Otherwise, can someone think of another way to possibly make this work? The stick prevents something from being mounted in the middle like in a squad car, so I don't know. Might have to give up on this one.
Touchscreen DVD Navigation - 10" Bazooka Subwoofer - Kenwood Speakers - Toyota Premium Horn set AFE Pro Dry Air Filter - modified air intake box - 1ZZ-FE Throttle Body - Ultra Racing Rear Sway Bar & Front Strut Bar NST in cabin & engine bay SSK's - TWM shifter base bushings & cable bushings - Megan Racing C-Pillar Brace |
![]() ![]() ![]() ![]() Drives: 2009 Yaris Hatchback Join Date: Feb 2009
An E-10 Torx socket will remove the four bolts holding in the passenger's seat
that or and 8mm 6point socket. its really tight. just dont round the head off.
Before you yank the seat, check out ram-mount. They have some nice mounts that would work without pulling the seat. There is a Yaris specific one that mounts to the passenger seat rail:
![]() http://www.ram-mount.com/CatalogResu...9/Default.aspx |
for $250 that is a pretty good solution...
| Which of These Car Companies Will Go Bust First? | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 23 | 11-16-2008 10:50 PM |
| Anyone in So Cal needs work on their Yaris | Bdaslug | California | 24 | 08-26-2007 05:10 AM |
| Im trying to figure out a easy way to make my yaris fast... help! | nsracing | Performance Modifications | 61 | 04-11-2007 08:33 PM |
| Tachy Idea | HTM Yaris | Cosmetic Modifications (Exterior/Interior) | 6 | 01-20-2007 05:09 AM |
| Install a Yaris deck into a Matrix... bad idea?? Help needed!! | SimmZ | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 12-17-2006 01:01 AM |
