Old 07-29-2007, 01:44 PM   #1
ChinoCharles
Drives: LB
Venting...
RUNNING WIRES THROUGH THE DOOR JAMBS OF A 2007 TOYOTA YARIS IS THE MOST ANNOYING TASK IN THE HISTORY OF MANKIND!!!!!!!!!O@IJ(OIH@(*ERHJ@R(HJWurq9rew9parj2 r209roheo
Old 07-29-2007, 01:46 PM   #2
hang'em outside, techno-punk style!
Old 07-29-2007, 05:02 PM   #3
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Its not that hard. You can pop the boot out of either side pretty easily. Run a piece of stiff wire through first and tape your flaccid ones to it.
Old 07-29-2007, 05:51 PM   #4
bigsky2
Cousin Vitz
bigsky2's Avatar
I used a wooden chopstick which worked quite well.
But yes, it's a pain in the ass.
Having a 5-DR Yaris means I have twice the fun with wiring through the boots.
Old 07-29-2007, 09:16 PM   #5
ChinoCharles
Drives: LB
I did it momma! Pliers to the rescue!
Old 07-29-2007, 09:42 PM   #6
redyaris
Shiny Chromey Coolness
redyaris's Avatar
You have caught the anal wiring disease that struck Violin earlier. Just be simple and tuck em under the mirror trim.
Old 07-29-2007, 10:42 PM   #7
GabL
I want JDM bumpers!
GabL's Avatar
Drives: 5 Dr Yaris RS in Blazing Blue
What's the reason for running the wires at the door jambs?
GabL is offline   Reply With Quote
Old 07-30-2007, 12:59 AM   #8
20,000V electrified dooor handles as a theft deterrent...
Old 07-30-2007, 01:14 AM   #9
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
That sure will shock the piss out of ya!!!!!
Old 07-30-2007, 02:10 AM   #10
ChinoCharles
Drives: LB
I rewired my power windows for a different switch mounting location. I like the new setup a LOT better.
Old 07-30-2007, 02:19 AM   #11
Black Yaris
der Zeck
Black Yaris's Avatar
where did you move them to? no longer in the center?
Old 07-30-2007, 02:21 AM   #12
Black Yaris
der Zeck
I just ordered some fogs from Jimcat, so I am going to have some fun wiring myself here in a week or so when they show up
Old 07-30-2007, 06:43 AM   #13
bigsky2
Cousin Vitz
bigsky2's Avatar
Speaker wire, lighting wire, anything electrical should be wired through the boot of the door jams.
Pull off one side of the boot and you'll see several electrical wires for door locks, windows, etc. because any electrical wiring should be tucked away neatly and not come into contact with moisture.
