Old 03-18-2011, 01:45 PM   #1
DIY: 2006-2011 Yaris OEM Cruise Control Complete Installation
The 34 page PDF file below is a complete DIY for installing OEM Cruise Control on a 2006 to 2011 Yaris.
This will only work for US/Canda/Puerto Rico Yaris, as Yaris from all other areas lack the built-in ECM programming for Cruise Control. Vehicles from other areas must use an aftermarket cruise control system.
Any procedure that requires 34 pages of documentation may seem intimidating, but this installation is really not difficult. I tried to add as much detail as possible to clarify the parts where people who have installed cruise control have had questions.
This guide is broken up in to seven sections encompassing the following:
Section 1: OEM Cruise Control Stalk Installation.
Section 2: Steering Column Connector D3 Pin Installation
Section 3: ECM Connector A21 Pin Installation
Section 4: Connecting the ECM Pin to the Steering Column Pin Through the Firewall
Section 5: Cruise Control Clutch Switch Installation
Section 6: Optional Cruise Control Indicator Module Installation
Section 7: Verifying Operation
http://tinyurl.com/CruiseDIY
Old 03-18-2011, 03:36 PM   #2
white_rice
white_rice's Avatar
Drives: 2008 Toyota Yaris LE
Send a message via MSN to white_rice
Thank you very much Scott. Doing the install tomorrow.
white_rice is offline   Reply With Quote
Old 03-19-2011, 02:45 PM   #3
cdu
Drives: 2007 Yaris Sedan - Auto
Wow...great info Scott and kudos to you for your hard work on putting this all together! I'll be ordering the parts through Toyota this week!
cdu is offline   Reply With Quote
Old 03-19-2011, 03:00 PM   #4
cdu
Hey Scott...tried replying to your message but it doesn't work. So here it is:
*How do I go about buying these parts from you? Are there additional parts to purchase (wires, connectors, etc.) on top of what you supply? Or is this a "turn key" kit?
Thanks again!
Charles
Old 03-19-2011, 05:19 PM   #5
pennyracer
boydstir
pennyracer's Avatar
Drives: 08 yaris liftback
Send a message via AIM to pennyracer Send a message via Yahoo to pennyracer
sorry scott but i did not see the price for the all the goodies i have 08 hatchback automatic and not need led indicater light set up just everything else can u help
pennyracer is offline   Reply With Quote
Old 03-19-2011, 11:14 PM   #6
swidd
Drives: Yaris HB
pennyracer: at minimum you just need
the single wire that plugs into the ECM ($~20, order by part number from a dealership),
~10 ft of thin wire,
and any switch of your liking (4-way ($15+shipping), push-buttons ($3-10)).
Old 03-19-2011, 11:38 PM   #7
.Kevin.
I ain't even mad
.Kevin.'s Avatar
How much does cruise control at the dealership even cost to have put on?
Old 03-20-2011, 08:53 AM   #8
The quotes that I have seen for Cruise installation by the dealer have been around $500. I am not sure if they are still doing so, but in the past for non-factory cruise control installation they always used the Rostra aftermarket system, rather than taking advantage of the ECM's built in functionality.
Old 01-07-2012, 12:54 AM   #9
Bar_Red_Yaris
Drives: 2009 Yaris sedan
PM sent =)
Bar_Red_Yaris is offline   Reply With Quote
Old 03-27-2013, 07:59 PM   #10
AlphaFox78
Drives: 07 Yaris Hatch
scott, your mailbox is full
AlphaFox78 is offline   Reply With Quote
Old 03-27-2013, 08:02 PM   #11
Sorry about that - I just cleaned it up.
Old 03-31-2013, 02:01 AM   #12
Sum1Kool
Here for the Ride...
Drives: 2010 Yaris 2-door Polar White
Do you still have one if these? Do you have the CC clutch switch?
Thank you.
Sum1Kool is offline   Reply With Quote
Old 04-11-2013, 04:19 PM   #13
joech
Drives: E71
Re: Cruise control
I got the oem cruise stalk, pins and clutch switch from Scott. The parts got here so fast that I didn't have a chance to read the cruise DIY carefully. BTW Scott is great to deal with and he always willing to help if you run into any issue.
Install took about 2 1/2 hours and half the time was spent fishing the wires through the firewall. I ended up cutting a piece of coat hanger in order to fish the clutch switch wire above the clutch pedal. I also removed the battery since I couldn't figure out where the wire would come out. Once the wires got through the firewall the rest of the install was pretty straight forward. I did have a bit of a problem getting one of the pins into the D3 connector. But once the pins are properly in place, I went out for a quick drive and the cruise works like a charm.
Thanks again Scott.
Joe
joech is offline   Reply With Quote
Old 04-19-2013, 04:43 AM   #14
Kubcat
Drives: 2006 and 2013
First I would just like to say I have just found this forum and am very excited to find all this info. Thank you to everyone who contributes.
Does anyone know if this cruise control addition will work on a 2013 Yaris right hand drive 1.3 automatic built for the Australian market? Only the base model (ours) doesn't have cruise control and we would love to add it.
We also have a 2006 but it is not drive by wire and we don't want an aftermarket kit so if I can put it on the 2013, that will be the one we take on longer drives.
Kubcat is offline   Reply With Quote
Old 04-19-2013, 07:58 AM   #15
I have shipped cruise control parts to Australia for installation on 3rd generation Yaris with the 1.5L engine. I am not sure about it working on the Australian 1.3L, although it does work for the European 1.33L Yaris.
Old 04-20-2013, 05:08 AM   #16
Kubcat
Well I am happy to be the tester.
I will PM you about how to get the parts.
Old 04-26-2013, 03:25 PM   #17
Diagnostic
Diagnostic's Avatar
Drives: Yaris 5dr 998cc Edition 2012
Hi Scott
I have a 2013 998cc UK 'Edition' (base model) Yaris and would love to fit cruise, is it possible to fit the ECM based kit to my car and if so do you supply the complete kit Scott?
All the best.....
Diagnostic is offline   Reply With Quote
Old 04-26-2013, 08:19 PM   #18
Originally Posted by Diagnostic View Post
Hi Scott
All the best.....
My understanding is that only the 1.33L 2012+ European Yaris supports cruise control. Do you know if cruise is offered as an option on any of the UK 998cc Yaris?
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 01:58 PM
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
