Old 06-13-2007, 09:41 PM   #1
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Who makes camber bolts?
I need some.
Old 06-14-2007, 04:57 PM   #2
nick1983
nick1983's Avatar
Drives: 2007 Toyota Yaris sedan
Me too, I need negative.
nick1983 is offline   Reply With Quote
Old 06-14-2007, 05:34 PM   #3
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
You guys check with Invision, Wesellcarparts and Dezod? I think heylookatjames had camber bolts but not sure where from. Doesn't one of the thai guys have camber bolts?
SPONSORED BY
Old 06-14-2007, 08:03 PM   #4
largeorangefont
Break'em off some.
I bought some on Ebay for a Scion XB for $15 shipped. We will see if they fit :)
Old 06-14-2007, 08:30 PM   #5
Black Yaris
der Zeck
Black Yaris's Avatar
I am pretty sure these are just a smaller diameter grade 8 bolt
Old 06-14-2007, 08:54 PM   #6
brickhardmeat
Lonesome Cowboy
there is a guy here with these
Toyota OEM 12.4mm Front camber bolts (-2 deg camber)
http://www.yarisworld.com/forums/sho...t=camber+bolts
SPONSORED BY
Old 06-14-2007, 09:47 PM   #7
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
My local alignment shop came up with these no-name bolts that gave my car the camber I wanted. Its adjustable from 0-2 degrees negative I believe.
cleong is offline   Reply With Quote
Old 06-15-2007, 12:11 AM   #8
largeorangefont
Break'em off some.
No it is an eccentric bolt, just like the one above.
Old 06-15-2007, 12:14 AM   #9
largeorangefont
Break'em off some.
Old 06-15-2007, 12:59 AM   #10
Black Yaris
der Zeck
then you can get them at Napa
Old 06-26-2007, 10:07 PM   #11
brickhardmeat
Lonesome Cowboy
you ever get the camber bolts installed?
SPONSORED BY
Old 06-26-2007, 11:38 PM   #12
largeorangefont
Break'em off some.
I'm installing them this weekend. I have a camber guage I will use to dial in the camber.
Old 06-27-2007, 08:49 AM   #13
YamilR
YamilR's Avatar
Drives: Absolutely Red Liftback
Send a message via Yahoo to YamilR
http://www.ptuning.com/html/search-r...c&cmbYear=2007
YamilR is offline   Reply With Quote
Old 06-27-2007, 10:49 AM   #14
brickhardmeat
Lonesome Cowboy
cool
SPONSORED BY
Old 06-27-2007, 11:13 AM   #15
largeorangefont
Break'em off some.
Save $10 and get them on Ebay. Mine were $15 shipped, they are the same ones.
Old 06-27-2007, 11:32 AM   #16
brickhardmeat
Lonesome Cowboy
maybe kinda dumb question. Can you still use tuner nuts on these?
SPONSORED BY
Old 06-27-2007, 06:09 PM   #17
largeorangefont
Break'em off some.
Yea. These are the bolts that attach the bottom of the strut to the spindle. There are 2 per side. You replace the upper bolt on each side with the camber bolt and leave the stock bolt on the bottom.
Old 06-27-2007, 08:37 PM   #18
brickhardmeat
Lonesome Cowboy
I see it is beginning to make sense to me now. Thanks for explaining that. I'll be interested in hearing how your's performs when you get it adjusted.
SPONSORED BY
Camber kit FunkyCole Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 02-05-2009 05:28 PM
Camber kit FunkyCole Performance Modifications 0 06-12-2007 08:26 PM
The ultimate question... WHY? Beware, nothing in this post makes sense. spkrman Off-topic / Other Cars / Everything else Discussions 26 05-30-2007 02:01 AM
Dont forget the camber bolt. nurburgring Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 05-23-2007 05:39 AM
Camber Kit? LoudYar Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 04-12-2007 10:58 AM
