DIY: 2006-2011 Yaris OEM Cruise Control Complete Installation
The 34 page PDF file below is a complete DIY for installing OEM Cruise Control on a 2006 to 2011 Yaris.
This will only work for US/Canda/Puerto Rico Yaris, as Yaris from all other areas lack the built-in ECM programming for Cruise Control. Vehicles from other areas must use an aftermarket cruise control system. Any procedure that requires 34 pages of documentation may seem intimidating, but this installation is really not difficult. I tried to add as much detail as possible to clarify the parts where people who have installed cruise control have had questions. This guide is broken up in to seven sections encompassing the following: Section 1: OEM Cruise Control Stalk Installation. Section 2: Steering Column Connector D3 Pin Installation Section 3: ECM Connector A21 Pin Installation Section 4: Connecting the ECM Pin to the Steering Column Pin Through the Firewall Section 5: Cruise Control Clutch Switch Installation Section 6: Optional Cruise Control Indicator Module Installation Section 7: Verifying Operation http://tinyurl.com/CruiseDIY
Thank you very much Scott. Doing the install tomorrow.
boydstir
sorry scott but i did not see the price for the all the goodies i have 08 hatchback automatic and not need led indicater light set up just everything else can u help
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
pennyracer: at minimum you just need
the single wire that plugs into the ECM ($~20, order by part number from a dealership), ~10 ft of thin wire, and any switch of your liking (4-way ($15+shipping), push-buttons ($3-10)). |
I ain't even mad
How much does cruise control at the dealership even cost to have put on?
The quotes that I have seen for Cruise installation by the dealer have been around $500. I am not sure if they are still doing so, but in the past for non-factory cruise control installation they always used the Rostra aftermarket system, rather than taking advantage of the ECM's built in functionality.
![]() Drives: 2009 Yaris sedan Join Date: Jun 2011
PM sent =)
#8 | |
Ruler of the free world
Drives: 09 Yaris 2D HB Join Date: Jul 2010
Dont know why they wouldnt use the built in feature.
![]() Drives: 07 Yaris Hatch Join Date: Sep 2010
scott, your mailbox is full
Sorry about that - I just cleaned it up.
Here for the Ride...
Drives: 2010 Yaris 2-door Polar White Join Date: Jul 2007
Do you still have one if these? Do you have the CC clutch switch?
Thank you. |
![]() Drives: E71 Join Date: Mar 2013
Re: Cruise control
I got the oem cruise stalk, pins and clutch switch from Scott. The parts got here so fast that I didn't have a chance to read the cruise DIY carefully. BTW Scott is great to deal with and he always willing to help if you run into any issue.
Install took about 2 1/2 hours and half the time was spent fishing the wires through the firewall. I ended up cutting a piece of coat hanger in order to fish the clutch switch wire above the clutch pedal. I also removed the battery since I couldn't figure out where the wire would come out. Once the wires got through the firewall the rest of the install was pretty straight forward. I did have a bit of a problem getting one of the pins into the D3 connector. But once the pins are properly in place, I went out for a quick drive and the cruise works like a charm. Thanks again Scott. Joe |
![]() Drives: 2006 and 2013 Join Date: Apr 2013
First I would just like to say I have just found this forum and am very excited to find all this info. Thank you to everyone who contributes.
Does anyone know if this cruise control addition will work on a 2013 Yaris right hand drive 1.3 automatic built for the Australian market? Only the base model (ours) doesn't have cruise control and we would love to add it. We also have a 2006 but it is not drive by wire and we don't want an aftermarket kit so if I can put it on the 2013, that will be the one we take on longer drives. |
#14 | |
I have shipped cruise control parts to Australia for installation on 3rd generation Yaris with the 1.5L engine. I am not sure about it working on the Australian 1.3L, although it does work for the European 1.33L Yaris.
#15 | |
I will PM you about how to get the parts. |
#16 | |
Toyman162
Drives: 2007 Yaris YRX 3-Door Join Date: May 2013
I, too, am from Australia. I have a 2007 1.5 Auto Yaris, and am interested in your cruise control for my car. Do you know if the unit(s) you have sent to Australian owners have worked OK? If so, how much are the parts shipped here? Thanks, John. |
They have worked for 2012 and newer Yaris, but I am fairly certain that they will not work for 2006-2011 Australian Yaris.
![]() Drives: 2012 Yaris YR Hatch Join Date: Jan 2013
I bought a cruse kit off CTScott for my 2012 1.3l Yaris and it worked perfectly and took me 20 minutes to install.
Conrod Logan City Queensland Australia |
| Cruise Control Available for 06/07 Yaris | TOYOTaejien | General Yaris / Vitz Discussion | 8 | 08-27-2010 12:58 PM |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
