Old 07-07-2007, 08:46 AM   #1
Sway84
Sway84's Avatar
Drives: 07 Yaris HB
Send a message via MSN to Sway84
how can u test a sub? URGENT
URGENT.....how can u test a sub without installing it into your car? URGENT
Rice on, Rice Off
Ron Cabading
Sway84 is offline   Reply With Quote
Old 07-07-2007, 11:25 AM   #2
punch
punch's Avatar
Drives: 2007 Yaris Sedan "D" package
not sure how but seen it done with a multimeter....
punch is offline   Reply With Quote
Old 07-07-2007, 11:39 AM   #3
earljail
earljail's Avatar
Drives: 07 Yaris Hatch 5speed
Not really recommended, but you can hook it up directly to the wall AC plug, it'll give a 60hz sound.
Or, you can hook it up to any home or car stereo, just don't play it loud.
earljail is offline   Reply With Quote
Old 07-07-2007, 09:15 PM   #4
Capagotks
Chode
Capagotks's Avatar
Drives: Silver 5 Door YRX 1.5L I4
Send a message via MSN to Capagotks
search for SSS base test (silicon sound system) is a sound file you play over the sub, tests the range of the sub from 360 hertz to 10 hertz.
Capagotks is offline   Reply With Quote
Old 07-07-2007, 10:16 PM   #5
punch
punch's Avatar
and how do you test the sub without hooking it up??? people read what is being asked!!!
"URGENT.....how can u test a sub without installing it into your car?"
Old 07-07-2007, 11:34 PM   #6
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
go ring your local audio dealer.......dont spend time waiting for a reply here....most people might know or dont know......better to ring someone locally and get a straight up answer
Old 07-08-2007, 05:13 AM   #7
Capagotks
Chode
Capagotks's Avatar
there is no way to test it without hooking it up
Old 07-08-2007, 11:34 AM   #8
xed
xed's Avatar
Drives: '08 Polar White 3dr
Test to see if it isn't blown?
If so then just grab a new 9v battery and connect it to the speaker terminals. If it jumps "in" then you hooked up your + and - backwards. Hook it up correctly.
If the speaker jumps "out" to the full travel of the speaker then it's not blown. If it doesn't move or barely moves then it's blown.
xed is offline   Reply With Quote
Old 07-08-2007, 09:04 PM   #9
actually, you said "without installing it in your car", NOT "without hooking it up". I think most people read what was being asked.
Ask a specific question, give some background maybe? and you'll get great answers on here.
Old 07-09-2007, 10:34 AM   #10
Turbo&Auto
Turbo&Auto's Avatar
Drives: 07
Connect an ohmeter to it. Put the meter on Ohms, it should read the voice coil resistance (2, 4, or 8 Ohms typically) If it reads a short across the plus and neg of the speaker, its SHOT.
Turbo&Auto is offline   Reply With Quote
Old 07-09-2007, 02:16 PM   #11
contraband831
El Huevo
contraband831's Avatar
Drives: 2007 Liftback
ask it a simple question like "what is 2+2?" if it answers correctly, it is fine! and if it does not answer, then it probably does not work...
JUST INSTALL THE SPEAKER, IF YOU HEAR SOUND, BINGO! IF NOT THEN TAKE IT TO A PROFESSIONAL STEREO SHOP.
Test Car needed for BlueBat overlays Turbo&Auto General Yaris / Vitz Discussion 12 07-24-2009 02:35 AM
I test drove a Yaris, Versa and FIT CanadaCraig New YARIS Purchase Forum 41 11-29-2008 09:18 PM
I finally test drove a Yaris Hatch... ECHOKnight2000 New YARIS Purchase Forum 10 02-01-2007 12:18 PM
Seeking Hatchback owners to help with parts test why_14 General Yaris / Vitz Discussion 2 12-05-2006 11:16 PM
