Old 07-29-2007, 01:59 AM   #1
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
A cold air intake idea
Thought crossed my mind - the stock airbox has its merits for everyday driving, being quiet and all. It sucks air from behind the front headlamp.
If you wanted to go out at night for some spirited driving, or at the track on the weekends, it still sucks air from the same place.
I am thinking of rigging up a cold air intake to the blanking plate for the front foglamp. I wouldn't use it all the time, just when I am feeling a bit more frisky than normal. I am told a CAI drags in quite a lot more garbage than normal as well, so I won't keep it open all the time.
I would remove the stock airbox's snorkel and just plumb the CAI into the airbox itself. Or return everything to stock and just cap the foglamp cover back.
Could be fun for a DIY project, given I've removed the bumper before.
Leong's NCP91 Toyota Yaris E
Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38
Stebel horns, Philips Silvervision turn indicator bulbs
TTE Lowering Springs, Camber bolts
TRD Blue brake pads
Fujitsubo Super Wagolis axleback exhaust
DC Sports header
cleong is offline   Reply With Quote
Old 07-29-2007, 02:29 AM   #2
I'm not 100% sure what you mean, but a removable tube that connects the airbox to the foglamp hole in the bumper? How would you go about engaging/disengaging it?
I'd say go for it, it would basically be a very low cost alternative to a replacement intake, or even a guideline for people with some sort of short ram intake to get some fresher air in. I was actually considering a small hood scoop, but this would be far more stealthy!
Old 07-29-2007, 04:17 AM   #3
i think a member here did something very similar to what you have in mind.
Old 07-29-2007, 07:50 AM   #4
cleong
cleong's Avatar
Ok, in the sequence of what I want to do:
Cold Air Intake:
1. Remove bumper. Prise off the left side foglight blanking plate.
2. Remove snorkel from stock air box.
3. Fit tube from opening left in stock air box to where the foglight opening is in the bumper.
4. Put snorkel and foglight cover away.
Normal:
1. Replace the foglight cover in the bumper.
2. Move cold air intake tube away from airbox.
3. Replace standard intake snorkel.
TRD Blue brake pads
DC Sports header
Old 07-29-2007, 12:30 PM   #5
Meteorite Man
Passin' The Gas...Station
Meteorite Man's Avatar
Drives: Same As You But Different
Send a message via Yahoo to Meteorite Man
If you're into plumbing and have the room, put a "butterfly valve" down towards the bottom intake. Doesn't have to be huge. I was vacuuming the pool and I shut one valve out of two to keep better presure and suction to the vacuum head. It's looking pretty easy to install, you'd just reach up under or through the engine bay and give it a twist. Or......have you ever seen the valves they use on motorhomes and campers for the waste tanks? It's just a slide that when you pull the handle towards you it opens and then push it away it closes. It's sealed.
I've seen the butterfly valves in different sizes at the pool supply place.
MY Gas Station Attendant Misses Me...
Chuck
Meteorite Man is offline   Reply With Quote
Old 07-30-2007, 09:49 AM   #6
Turbo&Auto
Turbo&Auto's Avatar
Drives: 07
More and more people with CAI's or SRI's on 05+ Toyota's are having lean conditions!! Get a scan tool or something when you try it. Something with the DBW system is not liking intakes.
Turbo&Auto is offline   Reply With Quote
Old 07-30-2007, 06:44 PM   #7
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
I didnt actually change the MAF sensor position. I have a 07 sedan and I fiberglassed off the factory opening on the airbox(on the sedan it opens up right into the engine bay). I cut two openings in the airbox and used aluminum sheets to direct cold airflow to the box, then used aluminum diamond plate to seal off the whole airbox from the warm air of the engine bay. I threw in a drop-in K&N air filter and called it good.
Should have gained a couple horsepower without causing the dreaded CEL's.
EDIT: this method also eliminates the sucking in of alot of the road grime and garbage you get when you put the airfilter way down below the bumper where it gets water and god knows what else up the intake tube. It is a way to keep the MAF in the same place and not get CEL's, to keep your air filter cleaner, and to still have the benifits of good gas milage, the proper air to fuel mixture, and the horsepower and sound of a CAI.
Old 07-30-2007, 08:45 PM   #8
Turbo&Auto
Turbo&Auto's Avatar
Drives: 07
The problem isnt the MAF location its the increased air flow. Increased airflow = higher MAF output voltage = different fuel trims. Too far from stock causes funky changes in the long and short term trims.
Nice setup though :)
Old 07-31-2007, 10:09 AM   #9
drecian
drecian's Avatar
Drives: '07 YR 3dr
I've run that setup with the cold airbox feed on another car ('00 Mazda 626; 2L 4cyl) and didn't seem to have any problems. I covered the pipe opening wiht a fine wire mesh to stop any leaves and debris, but checked the air filter frequently and didn't seem to dirty up any faster. I did it with the 3in silver flex tubing and found it to give a little better power in the top end (but dyno verified :P) and a meatier induction noise. Could have problems if you drive in dusty conditions or lots of water (1ft deep?), but everything seemed to be alright on my old car. If you're concerned, I guess you could just end the tubing in front of the wheelwell and put another cheap cone/pod-style filter on it; anything to draw air further from the radiator would help I guess.
I'll probably do the same on the Yaris when I have the time, can't really beat it for value ($20?).
drecian is offline   Reply With Quote
Old 07-31-2007, 10:53 AM   #10
Turbo&Auto
Turbo&Auto's Avatar
Drives: 07
I understand it worked on another car, the problem is this car though and its drive by wire system. For some strange reason the DBW cars from Toyota dont react well to changes in the intake system. At least with the Matrix. I cant see how it would be different for this car though, same setup just different tuning for the engine.
Does anyone have a CAI and a wideband O2 sensor on their Yaris???
Old 07-31-2007, 01:27 PM   #11
tmyers82
Drives: Toyota Yaris Hatchback
Heres an idea
Watching a movie about street racing DOES NOT MAKE YOU A TUNER!!!
tmyers82 is offline   Reply With Quote
Old 07-31-2007, 05:05 PM   #12
redyaris
Shiny Chromey Coolness
redyaris's Avatar
oh i see a lock coming on this thread.
Old 09-14-2007, 11:05 AM   #13
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
Originally Posted by tmyers82 View Post
Heres an idea
That thing is scary
i think that car had a turbo but when some people sell there car they take a lot of those things off
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 09-16-2007, 05:19 PM   #14
pp.sweet
pp.sweet's Avatar
Drives: Red Yaris HatchBack
Why would the mod's lock this thread ???
Don't hate. congratulate!!
wELCOME TO oUR wORLD..
pp.sweet is offline   Reply With Quote
Old 09-16-2007, 05:30 PM   #15
KSIbucky
KSIbucky's Avatar
ya
7 Color Tach
Fujita Intake
Blitz exhaust
(Next is DC Header)
Old 09-16-2007, 06:17 PM   #16
staticorex
staticorex's Avatar
Drives: Sc'd Yaris Sedan.
wow. Just wow. I hope that pic was made as a joke. :p
Also, after installing my CAI I noticed the filter is right behind the fog light cap. So on the dyno I removed the cap to see about a difference. None. About 6 pulls with the cap and 6 without. No diff. In case that was close to what you're talking about. :)
Old 09-16-2007, 06:39 PM   #17
KSIbucky
KSIbucky's Avatar
i think its to much work i would research a lot before you go with it also we need to know what your talking about
7 Color Tach
Fujita Intake
Blitz exhaust
(Next is DC Header)
Old 09-16-2007, 08:08 PM   #18
nick1983
nick1983's Avatar
Drives: 2007 Toyota Yaris sedan
Are you looking for more of a "Ram Air" setup. That forces air into the airbox?
nick1983 is offline   Reply With Quote
Intake Systems Decision Maker.. Blenjar Performance Modifications 25 09-15-2007 11:07 PM
guess what I'm waiting for and how much I paid? Ric n Sov's Vitz RS General Yaris / Vitz Discussion 27 06-27-2007 08:36 PM
cold air intake PolrWht07 Performance Modifications 8 05-28-2007 10:25 AM
Cold Air Intake vs. Short Ram Intake nevermorez Performance Modifications 1 01-24-2007 05:25 PM
Cold Air Intake ? pegcityrs Performance Modifications 47 04-17-2006 08:43 AM
