Old 09-30-2024, 09:44 PM   #1
rhrs1987
Rodderick
Drives: Yaris 2016 Premium Mex
Question Yaris 2016 fuel filter: many contradictory posts or references
Hey guys:
According to my manual (Yaris 2016 sedan, LE), fuel filter must be serviced at 96 months. I've read it's included inside the pump, that it is not serviceable. Another posts says it is possible.
My Toyota dealership just told me they don't service the filter, since it's included in the pump, but the manual states that it must be serviced "Fuel filter (including filter in fuel tank)".
So, which one is it? Should I also then change the pump?
Appreciate your help on this!
rhrs1987 is offline   Reply With Quote
Old 10-23-2024, 12:05 AM   #2
rhrs1987
Rodderick
Anyone?
Old 10-26-2024, 05:09 PM   #3
komichal
I would not care as long as the car behaves ok.
You can check the fuel pressure (or have it checked) if you really insist, but fuel filter cannot become suddenly clogged if you use normal gas on normal gas stations. It would take a lot of time and you would feel gradual loss of power, choke when accelerating, CEL can come up...
Old 10-27-2024, 09:43 AM   #4
If everything is running normal, no issues don't worry about it.
I have a 2006 with 404,000 kms on it and have never addressed the filter/pump in any way.
Old 10-01-2026, 08:20 PM   #5
davesyarissedan
Drives: stock 12 yaris sedan
i have a 2012 yaris sedan , US spec . and there is no seperate fuel filter . its in the fuel pump .
davesyarissedan is offline   Reply With Quote
Old 10-09-2026, 06:59 AM   #6
bairjo
Look up "XF22045 Fuel Filter Replacement for 77024-0D070" on Amazon. I used this aftermarket fuel filter on my 2010 last winter. Here is a video on youtube showing how this is done. Hope this helps.
https://youtu.be/OTtsgpBlcZY
fuel filter, yaris 2016
Wrong fuel filter... Lars DIY / Maintenance / Service 6 06-16-2023 11:41 PM
Changing the fuel filter wnavarro DIY / Maintenance / Service 6 09-18-2017 05:42 PM
