Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Central and South America
Old 07-26-2007, 12:56 PM   #1
carlosh
carlosh's Avatar
Drives: Yaris Sedan 2005 Motor 1NZFE
Send a message via MSN to carlosh Send a message via Yahoo to carlosh
Exhaust Pipe Size (Tamaņo del tubo de escape)
Bueno este tema lo saque de www.scionlife.com me parece bueno que se sepa a la hora de hacerle la tuberia a nuestros autos que tamaņo tomar de referencia.
Posted: 8/6/04 9:13AM Post subject: Exhaust Pipe Size.
This is just some ramble I thought of & had nothing better to figure out, this information is all done by me, so I know some of it might be wrong I am no math major. Use this information in any way you want, just dont blaim me for any problems you have with it.
American Standards:
Stock Pipe:
Pipe Size = 1.75"
Pipe Surface Area = 2.4"
Pipe 2:
Pipe Size = 2"
Pipe Surface Area = 3.14"
Pipe 3:
Pipe 3 Size = 2.25"
Pipe 3 Surface Area = 3.97"
Stock Pipe vs Pipe 2:
Increase in Diameter = .25"
% of Increase = 14.28%
Increase in SA = .74"
% of Increase = 30.83%
Stock Pipe vs Pipe 3:
Increase in Diamete = .5"
% of Increase = 28.57%
Increase in SA = 1.57"
% of Increase = 65.5%
Metric Standards*:
Stock Pipe:
Pipe Size = 45mm
Pipe Surface Area = 1590mm
Pipe 2:
Pipe Size = 50mm
Pipe Surface Area = 1963mm
Pipe 3:
Pipe Size = 55mm
Pipe Surface Area = 2375mm
Increase in Diameter = 5mm
% of Increase = 11.1%
Increase in SA = 373mm
% of Increase = 23.5%
Increase in Diameter = 10mm
% of Increase = 22.2%
Increase in SA = 785mm
% of Increase = 49.4%
* All the metric numbers are rounded for more simple math. Also The pipe 2 & pipe 3 size are different then the american standards, I did this to show if using mm to measure your exhaust & have pipes made in that size, its much easier to figure out.
Im sorry if information like this has been posted before. The infomation could be used for basics in helping you decide what size exhaust you want. It also shows how that just by increasing from 1.75" pipe to 2.25" pipe is a big difference, might make some people think about a full cat back in the 2" pipe size. This information is also just the pipe, when figureing exhaust flow one needs to know a lot more then just this information.
http://www.scionlife.com/forums/viewtopic.php?t=22925
Yaris/echo 1NZFE NCP12
-> TEIN High-TECH spring, Tower bar Generic, HOTCHKIS Sway bar
-> TRD Performance air filter, Stage 1 Gripforce F1 clutch
carlosh is offline   Reply With Quote
