Old 07-08-2007, 07:40 PM   #1
blueskana
blueskana's Avatar
Drives: 2007 Yaris LB
Racing weight
What are you guys running at and what did you do to get there?
1,960- LB/no options, rear seat/bracket, 15x6.5 helium/v710s, 1/3 tank.
blueskana is offline   Reply With Quote
Old 07-14-2007, 08:27 PM   #2
blueskana
blueskana's Avatar
Has anyone done a seat swap and know the weight of the stock seats and brackets? Thanks.
Old 07-14-2007, 10:28 PM   #3
03Z33
03Z33's Avatar
Drives: TCR10
stock seats are VERY light. Under 40 lbs total with sliders. I did some Recaro PP buckets and with the bracket, slider and side mounts they come out to almost the same weight as the stock seat, right around 10lb savings per side.
HOW did you get your car down to 1960, or better yet WHERE did you weigh it? Last time I had my car on the scales (corner balance) it came out to 2216 with no back seats and 3/4 tank of gas. I had ~ 90 lbs in the trunk (full size spare weighs 40lbs and ~50lbs in tools.
Old 07-20-2007, 07:57 PM   #4
blueskana
blueskana's Avatar
Thanks for the numbers on the seats. I'm going with the FX1 pros, but still working out the mounting. The seats are 16 lbs and the brackets are 20. I've got to find a way to mount them that doesn't weight more than the seats themselves. I weighed it at the public scales.
Old 07-20-2007, 10:32 PM   #5
cm07yaris
Drives: 2007 Toyota Yaris Blazing Blue
Send a message via AIM to cm07yaris
anyone know the weight of the stock 15 inch steelies?
cm07yaris is offline   Reply With Quote
Old 07-21-2007, 01:14 AM   #6
squareback
Drives: Non-Yaris
Heavy.
squareback is offline   Reply With Quote
Old 09-02-2007, 11:47 PM   #7
leasaunce
Drives: Toyota Yaris
should be around 7kg
leasaunce is offline   Reply With Quote
Old 07-21-2007, 11:06 PM   #8
cm07yaris
will i notice any improvements when i put my 15lb wheels on?
Old 07-23-2007, 08:16 AM   #9
red-jdm
red-jdm's Avatar
Drives: Yaris type E M/T
what wheels have you got? our stock 15" should weight around 6 kg, without tyres. So if your new ones weigh around 6.5 kg, then it means it's heavier
red-jdm is offline   Reply With Quote
Old 07-23-2007, 01:40 PM   #10
cm07yaris
I've got 16 inch 5Zigen FN01R-C, stated at 15 lbs each.
Old 07-23-2007, 01:56 PM   #11
blueskana
blueskana's Avatar
My barum's on stock steel weighed 25.5 lbs per wheel/tire. The ES100's on heliums came out to 19.5. I noticed a positive difference after the switch.
My stock seats, with brackets, came out to 48 lbs each.
Old 07-25-2007, 11:34 AM   #12
lifthard1
Drives: Black LB
Just weighed my 15" rims and tires at UPS for shipping with the hubcaps and lugs 30.8 lbs
lifthard1 is offline   Reply With Quote
Old 09-02-2007, 11:52 PM   #13
black2yaris
The Man In Black Lives
Drives: Black Sand Pearl L/B 'o7
the 5 wide spoke Toyota 15" alloys weight in at 19 lbs minus the nuts & tires. I know cause i sold them on Ebay & shipped them to FLA
black2yaris
The Man In Black Lives!
2007 2 door hatchback in Black Sand Pearl, A/T,rear spoiler,front & rear JDM badges,TRD CAI,TRD rear sway bar,exhaust tip,sill protectors,heximats,under dash blue LED's,short rubber ant,rear bumper protector,Toyota thin 7 spoke alloy wheels,pwr pkg,ABS,side curtain airbags,rear defogger,fog lights,mud guards,TYC tail lights,shift knob,tint all windows,security sys,keyless entry,clear paint protection all exposed front surfaces,TRD fuel cap,rubber dash & g/b mats
black2yaris is offline   Reply With Quote
Weight Savings 03Z33 Performance Modifications 30 01-31-2009 05:14 PM
batracer.com online web based racing Shadow102 Off-topic / Other Cars / Everything else Discussions 1 12-17-2006 10:47 PM
Buddy Club Wheels BulletProofAuto Sponsors Classifieds Area 8 10-19-2006 07:55 PM
Weight Savings - Removal, Reduction, Reminder.... TRD_Yaris Performance Modifications 17 08-12-2006 03:07 PM
