are u still 34/39?
Drives: flint mica yaris s sedan Join Date: Sep 2006
i decided to remove my front turn signals today, they were blinking fine at regular speed prior
then when i put them back, it's blinking faster...very ricey...like they are on crack speed did i blow some kind of regulator fuse? |
![]() ![]() ![]() ![]() ![]() Drives: 2007 Yaris HB Join Date: Apr 2007
I think its a warning thing--to let you know you have a bulb out (or going out) somewhere and you need to replace it.
#3 | ||
are u still 34/39?
looks like this is what it is...
http://www.f150online.com/forums/arc...p/t-41957.html Quote:
but i might just do what it says below since i want led so bad (something about how they blink, the slower the better) Quote:
Mr Attitude
Drives: Blazing Blue 5 Spd Join Date: Jun 2007
I had that happen in a Toyota truck I owned, turns out I tweaked the flasher thingy in the fuse box (sorry for the technical jargon
). By twisting it around lightly, I was able to slow them back down. Doesn't sound like that's your problem, but maybe?
It's scary to think that half the people surrounding you are below average...
Dont you have the HiLED rear signal LEDs?
I removed my prototypes Bob@HiLEDs sent me, after they did the same thing.. let alone were not even brighter then the stock halogens. |
Lonesome Cowboy
Drives: 2007 WHITE HATCHBACK Join Date: Feb 2007
load resistor?
SPONSORED BY
are u still 34/39?
i'm pretty sure they are not prototype but they are still blinking fast. i have to check with Bob@hileds if he can do something coz really it started happening when i installed the fronts but even after putting just the rear still no luck. originally i put the rears in and they didnt blink fast but now it doesnt matter. regardless what combination i install, they just blink fast. except, except if i use hazards but simple turn signals blink fast.
I didnt say yours were prototype. I said when i tested them, which was over 6 monyhs ago, my prototypes sent for testing caused this issue. Bob has said since then, they were building a load resistor into the bulb itself.
I think you neeed a LOAD BALANCER KIT - this place sells them
http://www.spiderlite.com/storeX2.html |
#10 | |
are u still 34/39?
![]() Drives: 2007 4dr yaris Join Date: Aug 2007
one of your signals on that side most likley out, reason why your gauge and other "ok" signals blink fast is because less resistance when one load (being the blown bulb) in the circuit is out.
are u still 34/39?
not really. i just put back all my stocks and all is well. the hiLEDs are just collecting dust.
are u still 34/39?
hileds recommended these led flashers but has any1 installed these already before(see attached) and where do they go? where can i buy some that are specified for sedan? i saw a couple but for european cars
you wont find a part specific for your car... its an electrical part.
im sure bob can walk you thru the simple hookup if you so needed. |
are u still 34/39?
led flasher from autolumination.com fixed my problem
![]() for those u want to buy it, it's item #: CF 18 ALT just had to cut some extra tabs that the CF 18 ALT had, plug and play. 1st removed compartment by left knee for easy access to main ECU |
| Any Yaris hatch rear suspension tweeks? | woof | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 26 | 12-05-2009 07:04 PM |
| s sedan HiLED rear turn signals | manborn | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 08-25-2007 06:54 PM |
| Hatch Turn signals | fred812 | General Yaris / Vitz Discussion | 27 | 03-20-2007 08:02 PM |
| Turn signal audible alert | paultyler_82 | Performance Modifications | 7 | 10-01-2006 11:21 AM |
| Turn signal bulbs | casterqc | Cosmetic Modifications (Exterior/Interior) | 2 | 07-15-2006 08:44 PM |
