Old 08-14-2007, 12:47 AM   #1
yuiedie
Drives: '07 liftback
15k service
anyone done it on their own? if i recall i think air filter change was recommended in addition to the normal oil change/tire rotation/brake inspection.
yuiedie is offline   Reply With Quote
Old 08-14-2007, 01:28 AM   #2
seanele
seanele's Avatar
Drives: '07 Blazing Blue LB, '09 Jetta
mine is now at 13000.
last oil change....at 11000.
last tire rotation...2 days ago (new rims/tires.. )
last brake check...dunno
last air filter change...dunno,
but i'm shopping for K&N since yesterday afternoon.
i will do all of this, when it hit exactly 15000
current: '07 Yaris LB - '09 VW Jetta
ex: '06 Beetle S(19x8.5 Audi A8) - MK4 GLi BMP(18x8 OZ, K04) - '03 GTi(17x7.5 Ronal, APR93) - '01 GLS - '88 GTi - '86 GTi - '83 GTi
seanele is offline   Reply With Quote
Old 08-14-2007, 09:11 PM   #3
aca72
aca72's Avatar
Drives: '07 Yaris S Sedan M5
Based on my preferred third party non-dealer Toyota service shop...
http://www.japanesebeetle.com/lexusgold.htm
At 15K, you do...
Engine oil, filter & drain Plug crush ring - replace
Engine air filter - cleaning
Cooling system & hoses - visual inspection
External belts - visual inspection of condition
Drive shafts - inspect boots, and re-torque shaft flange bolts
Fuel injection system - add fuel injection cleaner additive to fuel tank: inspect lines, connections & tank vapor vent system hoses;inspect fuel tank gasket condition.
Exhaust system - inspect mounts
Brake components - inspect condition of lines, hoses, master cylinder, calipers & rotors
Brake pads - measurement of remaining pads
Power steering system - check operation & linkages, add fluid if needed, visual inspection for power steering leaks
Undercarriage - visually check for damage and condition, inspect fuel tank bands.
Windshield wiper and washer - fill fluid, clean and inspect wipers
Electrical equipment and lights - check bulbs and operation of warning lights
Suspension - visually inspect ball joints, dust boots, shocks/struts and suspension arm bushings
Battery - load test, top fluid, clean battery terminals
Rotate tires,set tire pressures and check wear and condition of tires
Test Drive
Reset Maintenance light indicator when applicable
Automatic - replace ATF (if equipped) (N/A to WS type fluid transmissions)
Manual transmissions - replace fluid (if equipped)
Rear differential - replace 80W90 gear oil
A/C Filter - clean
Air Filter - clean
aca72 is offline   Reply With Quote
Old 08-15-2007, 04:22 PM   #4
Black Yaris
der Zeck
Black Yaris's Avatar
At 15K, you do...
Test Drive
A/C Filter - clean
Air Filter - clean
that is WAY off
Trans fluid is recommend to be replace every 30k on AT and MT
change OIL - obviously every 5k
at 15k
I would Check your air filter, it may need changed if you live in a dust area
I would check your brakes as well, depending upon how you drive/stop
Check alignment
Rotate tires-should be free with brake inspection
Old 09-26-2007, 05:05 PM   #5
Trilixia
Trilixia's Avatar
Drives: Black Sand Pearl Liftback
At 15K, you do...
Test Drive
A/C Filter - clean
Air Filter - clean
Price Check?
"That's Corny, Dude!!"
Trilixia is offline   Reply With Quote
Old 09-26-2007, 05:45 PM   #6
aca72
aca72's Avatar
Originally Posted by Trilixia View Post
Price Check?
I haven't done my 15K service yet so I cannot give you an actual amount. In my experience with my Civic, they first give me a written estimate, then they work on the car. When it's time to pay, they explain what they did and deduct certain items that was not necessary. In addition, with some friendly haggling, I get more discounts (been with them for more than three years). Sometimes it pays to know and be friends with your mechanic.
Old 08-15-2007, 02:59 PM   #7
Pavel Olavich
Drives: 2007 Yaris LB
Aca72,
Replaced the ATF at 15k? The manual says 100,000 I think...someone correct me if I'm wrong....
Replace manual tranny fluid at 15K? Another stupid thing...the manual does not call for this..again, someone correct me if I'm wrong.
Clean the A/C & air filter? That is stupid. Just replace it, as they're cheap.
Don't buy into the trust thing with any garage, especially those that don't adhere closer to the Toyota manual in regard to maintenence intervals.
How much are they charging you for these services?
You need to reconcile everything your mechanic does to the owner's manual.
Reality Check for you: Mechanics are in the same class as car salesmen, realtors, and many lawyers...buyer beware...don't get scammed or fooled.
They are not your friend.
Pavel Olavich is offline   Reply With Quote
Old 08-15-2007, 03:06 PM   #8
Turbo&Auto
Turbo&Auto's Avatar
Drives: 07
I love that you have to pay them to visually inspect things.....Dealer FTL!
Turbo&Auto is offline   Reply With Quote
Old 09-26-2007, 05:04 PM   #9
Trilixia
Trilixia's Avatar
I hate that. Their eyes are probably made out of gold or something...
Old 08-15-2007, 04:23 PM   #10
Black Yaris
der Zeck
I already relplaced my fluid in my trans so I could go to synthetic 75w-90 AMSoil
Old 08-15-2007, 05:12 PM   #11
aca72
aca72's Avatar
They have a small disclaimer if you went to their site...
"These schedules are recommended by Lexus and Toyota and are specially designed to meet the demands of Bay Area Traffic. These scheduled services include services in addition of those recommended by the manufacturer and may not be required to maintain the factory warranty. In most instances, these schedules below meets and or exceeds the manufacturer's recommendations."
The way I see it, I just tell them what I want and what needs to be done. For sure, some of the stuff are DIYs.
As for non-DIY people, the service schedule "meets and or exceeds the manufacturer's recommendations" which gives those people a peace of mind.
Finally, my main concern is the cost of the service. I learned that dealer service literally suck the money out of your wallet with efficiency. One of my option besides DIY is with these guys (Japanese Beetle) in the Bay Area.
Old 08-15-2007, 06:44 PM   #12
Pavel Olavich
The Toyota dealers in my area mail out coupons that show fairly good savings. I DIY most of my maintenence, but for those that don't, these coupons could be a way to go in getting Toyota dealer maintenence at very competitive prices, and since it is Toyota doing the service, it is probably done right.
30K throttle service jaggurnaut DIY / Maintenance / Service 39 09-11-2007 09:34 PM
Service in Phoenix Bretsuaz Southwest 4 06-10-2007 08:14 PM
Metro Atlanta Dealer Service Experiences redyaris Southeast 2 03-21-2007 04:59 PM
Do I need to hava a 1000-mile maintenance service?? hans_fh DIY / Maintenance / Service 3 11-24-2006 07:13 AM
Question about service to the yaris foober General Yaris / Vitz Discussion 3 04-25-2006 11:56 PM
