Old 10-22-2006, 11:25 AM   #1
envoy
Drives: 2007 Bayou Blue Yaris Liftback
SRS Light Stays on After Stereo Install
Hi all!
Thanks a lot to your help i just finished installing a 9 speaker (4 tweeter, 4 mid + 1 sub) speaker system into a Liftback. Everything sounds great!
But the one problem is now my SRS light stays on (the one right under the speedometer). We did remove the "40" back seat, on the right side and put the sub there. We also did put 2 crossovers and a large amp under the passenger front seat. We also did remove the two seat belts harnessed on the right hand side, but nothing electrical was attached to them so i dont think this was it.
I thought maybe voltage issues would cause this SRS light problem (due to two amps stealing power), but it stays on even when the radio is off.
Any ideas?
I will post pics of my install later this week when i am finished with some cosmetic stuff.
Oh, also, do you think something like this would void the dealer from helping me with the safety system under warranty?
Thanks!
envoy is offline   Reply With Quote
Old 10-22-2006, 01:20 PM   #2
Bones
Bones's Avatar
Drives: 07 Yaris S Type
Check if any wires under the carpet (where you installed the amps) got pinched or a screw went through any wires? If you did screw down the amp on the floor board, check underneath the car make sure the screws didnt hit anything.
Bones is offline   Reply With Quote
Old 10-22-2006, 05:42 PM   #3
punch
punch's Avatar
Drives: 2007 Yaris Sedan "D" package
Originally Posted by envoy
Hi all!
Any ideas?
Thanks!
i also agree, check under that front seat there are many sensors in the seats for the airbags...
punch is offline   Reply With Quote
Old 10-22-2006, 06:17 PM   #4
envoy
I think it has to be there too I just havnt found it yet.
I didnt bolt the amps down just placed some velcro unto the bottom of the amp and it then stuck well to the carpetting.
Old 10-23-2006, 05:45 PM   #5
punch
punch's Avatar
I would look under the seat is your amp hitting the bottom of the seat? there are many sensors on the bottom of the seat..
also you mention removing the seat belt harness's, there is a sensor near the door frame for them
Old 10-23-2006, 08:11 PM   #6
envoy
ya I did remove two of the rear harnesses on the right (not the front passanger seat) but nothing electrical was unplugged and I drove it since then without this light staying on. Hmm, ill play with the seat sensors tonite and let you know if i find anything.
Old 11-01-2006, 12:07 AM   #7
funkstrong
I have that same problem. Did you by chance disconnect the negative terminal of the battery when you were working on the car?
funkstrong is offline   Reply With Quote
Old 10-22-2006, 09:39 PM   #8
nick1983
nick1983's Avatar
Drives: 2007 Toyota Yaris sedan
nick1983 is offline   Reply With Quote
Anyone know where to get center stereo console piece to install head unit? ebowers83 Cosmetic Modifications (Exterior/Interior) 7 07-15-2011 12:13 PM
Fog light install 07yaris_fe Cosmetic Modifications (Exterior/Interior) 10 07-20-2010 01:18 PM
Interior Light Kit... for Canadian version?! Jem_hadar Cosmetic Modifications (Exterior/Interior) 5 08-17-2006 02:20 AM
