Old 09-22-2006, 02:42 AM   #1
IsLNdbOi
IsLNdbOi's Avatar
Closest to a HID kit?
Anyone know what replacment lights out there are the closest to HID lights without actually being a HID?
I'm looking for some for my '07 US LB.
Old 09-22-2006, 07:30 AM   #2
paultyler_82
Drives: 07 Meteorite Metallic Yaris LB
HIR bulbs are the closest standard Halogens to a HID, but I don't beleive there is a suitable HIR bulb for a H4 (9003) conversion...
You might try Sylvania Xtravisions, Osram (not Sylvania) Silverstar, GE Nighthawks, Phillips Vision Plus, or Narva Rangepower
paultyler_82 is offline   Reply With Quote
Old 09-22-2006, 07:37 AM   #3
IsLNdbOi
IsLNdbOi's Avatar
Can you link some HIR type lights? Thanks.
Old 09-22-2006, 01:13 PM   #4
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
If you like a slightly purplish look, you can try the PIAA Super Plasma GT-X.
Not mine:
They are much brighter than stock. I got mine here: http://www.velocityfactor.com/Script...?idproduct=654
Old 09-23-2006, 05:11 PM   #5
sam07yaris
sam07yaris's Avatar
Drives: 07 yaris sedan (silver) STICK
Not mine:
IF thats a marketing pic, then that would be a definite false advertising. Infinit's have H.I.D. on upper models but by looking at that pic that is DEFINATELY HID to make sales on a bulb thats non HID to claim it is. Trust me on that one bud. Purplish look is the LOWEST output in H.I.D. People, I must inform you to just stick with 4300 K. The majority are misinformed about the color of HID so please take a safety precaution for your self as well as other drivers to just stick with 4300 K and not pick dandy over the rainbow colors.
sam07yaris is offline   Reply With Quote
Old 09-23-2006, 05:55 PM   #6
IsLNdbOi
IsLNdbOi's Avatar
I've seen people's pics. on other forums of their PIAA Super Plasma GT-X's and they look just like the ones in the pic. Violin posted.
Old 10-23-2006, 11:05 AM   #7
theycallmebutter
Drives: Acura RSX Type-S
Send a message via AIM to theycallmebutter
Why don't you spend some money and get a legit HID kit. It gives you much higher intensity, much more lumens, they draw less power and they last almost 5 times longer then halogen.
Those Plasma stuff is merely color-coated glass and hence it affects your lumens (brightness). HID, like 4300K, gives you between 2900-3200 lumens, which is 3 times of brightness of halogen.
Read this toturial, especially the "MISCONCEPTION" part:
http://www.intellexual.net/hid.html
theycallmebutter is offline   Reply With Quote
Old 09-22-2006, 02:27 PM   #8
IsLNdbOi
IsLNdbOi's Avatar
That looks pretty nice. Anyone have pics. of Osram Silverstars or Sylvania XtraVisions in action?
Old 09-22-2006, 10:37 PM   #9
johnnyfive
johnnyfive's Avatar
with the osram, or sylvania the stock harness will be more than enough
ill go take a shot of my osrams right now, post it up in a few :)
edit: ehh no pictures due to insuficient digital camera, which provided only a superwashed out white blob...but they are nice bulbs, driving on the freeway i can see that my lights outreach the lights of the cars driving infront of me at times :)
johnnyfive is offline   Reply With Quote
Old 09-23-2006, 12:49 AM   #10
IsLNdbOi
IsLNdbOi's Avatar
So which ones do you have johnny, the Osram Silverstars or Sylvania XtraVisions?
To everyone else that has them as well, which is better the Osram Silverstars or Sylvania XtraVisions?
Old 09-23-2006, 05:00 AM   #11
paultyler_82
The Sylvania XtraVisions are the true US Equivalent of the Osram Silverstars, I believe... the Sylvania XtraVision, Sylvania Silverstar, and Osram Silverstars seem to all have the exact same specs, however the USDM Sylvania Silverstars have that nasty blue/purple glass that is actually cutting output because it's filtering part of the visible light output. The trick is that the bulbs have a slightly different filament and gas mix which allows them to "drive" a bit harder on the same wattage as a stock bulb, the only downside is that all three of these bulbs suffer from a slightly shorter lifespan than a standard Sylvania or Philips bulb, the US Sylvania Silverstars suffer from quality problems on certain types of bulbs as well, the Sylvania Silverstar H4's seem to be plagued by loose filament problems, or so the complaints I've heard would seem to indicate. I've had both Osrams and XtraVisions, and I've loved both, so you'll probably be happy no matter what, just that the XtraVisions can be found at your local auto parts store and Wal Mart, whereas the Osrams aren't sold in any US Store, you'll have to get them online.
I really wish there was a H4 (9003) convertable HIR bulb, as these things put out some great light, for those who aren't familiar, HIR is a Halogen Infared bulb. They are standard Halogens, but they look similar to a HID Capsule. The bulb has a coating that lets the visible light through but reflects the IR light back inward to "overdrive" the filament and gas for above conventional output.
Old 09-23-2006, 05:24 AM   #12
IsLNdbOi
IsLNdbOi's Avatar
Just got back from Wal-Mart. Wow, if the XtraVisions are so good, why does their packaging look so plain / ugly. :p
The packaging for the Silverstars is very nice, not that the packaging makes a better light.
Old 09-23-2006, 05:43 AM   #13
paultyler_82
Because Sylvania doesn't try to market them as a "Hi-Performance" bulb like they do those Silverstars (like I said, the US units are those purple/blue bulbs that actually cut output of true visible light due to the light filter.) The Osram Silverstars are in relatively plain packaging as well, and aren't as overpriced as those beautifully packaged substandard US Silverstars.
Old 09-23-2006, 06:15 AM   #14
IsLNdbOi
IsLNdbOi's Avatar
Just went to Sylvania's site. They have SilverStar and SilverStar Ultra. I've never seen the Ultras in store before.
They also have their own brand of HIDs called "Xenarc".
Old 09-23-2006, 06:27 AM   #15
IsLNdbOi
IsLNdbOi's Avatar
Ok, I think I'm gonna go w/ Violin's PIAA's. Now I just need to decide whether I want the:
PIAA H4 Super Plasma GT-X
or
PIAA H4 Xtreme White Plus
http://www.velocityfactor.com/Script...?idproduct=617
Would I need upgraded / heavier duty harnesses if I used either of these two PIAA models?
Old 09-23-2006, 09:47 PM   #16
paultyler_82
I've had PIAA bulbs, they're okay, but mostly just overpriced junk.
Old 09-24-2006, 12:05 PM   #17
Violin
Violin's Avatar
because?
Old 09-23-2006, 09:53 PM   #18
IsLNdbOi
IsLNdbOi's Avatar
Hmmm... What to do now.
I hate the stock headlights, but can't afford Chris07LB's high/low beam HID kit. What's the best option for me then? Osram SilverStars?
For Sale: Lexus GS Parts - L-Tuned Body Kit, TRD Strut Tower bar, 18"StaggeredWheels. TRD_Yaris Items for Sale by private party 6 05-06-2010 07:43 PM
Is aftermarket HID kit legal (in NJ)? Jfoofoo Cosmetic Modifications (Exterior/Interior) 25 03-19-2009 03:05 PM
My 6500k H4 HID Review [pics] Chris07LB Cosmetic Modifications (Exterior/Interior) 74 10-10-2006 08:19 PM
Interior Light Kit... for Canadian version?! Jem_hadar Cosmetic Modifications (Exterior/Interior) 5 08-17-2006 03:20 AM
Any front bumper/ hood stone chip issues? Where could I get Clear Bra kit? tifosi360 General Yaris / Vitz Discussion 9 08-07-2006 03:43 PM
