Old 04-01-2009, 07:38 PM   #1
andaconda
andaconda's Avatar
Drives: '09 Yaris Sedan
visor decal removal
Debadging the the trunk lid made me happy but I am much happier now that I have removed my air bag warning decals from my sun visors!
andaconda is offline   Reply With Quote
Old 04-01-2009, 07:47 PM   #2
Pics? How?
This issue of sun visor decals has been raised many times.
Old 04-01-2009, 07:48 PM   #3
ChinoCharles
Drives: LB
It has. Didn't someone black it out w/ sharpie once?
Old 04-02-2009, 09:47 AM   #4
andaconda
andaconda's Avatar
Pics? How?
I know I'm bad...
I should have taken pics while I was doing it, but I got caught up in the moment!
I took 2" masking tape and taped close around the decal.
I used "Goof Off" in the original small can that looks like lighter fluid.
Saturated a clean rag with the goof off and daubed it on the decal, got it plenty wet. Did that a couple times.
Then started to rub lightly in one direction as I kept the rag plenty wet and continued to use a section of the rag that was clean.
The decal will start to break down and roll off in little balls. Continue until you're finished.
Remove the masking tape and go over it one more time.
Then I took 91% alcohol and cleaned up the area.
It will leave a slightly raised and lighter area where that decal was, but in time it will blend back to where it should be.
As I was rubbing the decal off - some of the very small pieces fell onto the seats and carpet, but I used more masking tape rolled backwards on my hand to clean it up ( kind of like getting lint off of your black pants.)
Took me a total of 30min to do both visors.
Old 04-07-2009, 09:33 AM   #5
andaconda
andaconda's Avatar
UPDATE:
After a few days now -- Looks even better!
I hate those ugly yellow stickers!
Old 04-08-2009, 12:25 PM   #6
andaconda
andaconda's Avatar
Pics? How?
After a few days this is what it looks like.
Old 07-03-2009, 06:02 PM   #7
ellenbetty
ellenbetty
ellenbetty's Avatar
Drives: 2 2007 Yaris 3 door liftback
I would rather save my lungs and try something less toxic, like 440 sand paper.
ellenbetty is offline   Reply With Quote
Old 07-09-2009, 03:11 PM   #8
p0pNfr3sh
Drives: "09" yaris
Sand paper is a bad idea. I was thinking about trying a heat gun
p0pNfr3sh is offline   Reply With Quote
Old 07-10-2009, 04:09 PM   #9
smofskra
smofskra's Avatar
Drives: 08 Flint Mica Sedan
Send a message via MSN to smofskra Send a message via Yahoo to smofskra
Looks like I found my next mod. Im sick of those things and i have tried to peel them off several times before.
"Chrome wont get you home"
smofskra is offline   Reply With Quote
Old 07-10-2009, 05:19 PM   #10
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
good lord no, even if you tried very very hard not to singe the fabric, you will.
how bout something less hot, like a hairdryer.
Check out my Build thread:
Paintless Dent Removal - Dent Magician Chupacabra General Yaris / Vitz Discussion 3 01-27-2009 10:07 PM
Sedan Headlight removal Go4th DIY / Maintenance / Service 1 02-04-2007 05:46 PM
Weight Savings - Removal, Reduction, Reminder.... TRD_Yaris Performance Modifications 17 08-12-2006 02:07 PM
