Old 02-14-2011, 02:21 PM   #1
barryware
A/C compressor - Always on
Hi.. I searched the forums and found that there is a switch on the back of the air selector dial.. Floor , floor defrost, full defrost, etc... that allows the compressor to run when in defrost mode even though the AC button is not pressed or illuminated
My AC compressor seems to be running even though the AC switch is not on. I had a similar problem when my water pump was failing.. When I went to change the pump, I found some pink crusty stuff had fallen into the compressor clutch and kept it engaged even though electrically, it was not supposed to be. A squirt with the garden hose cleared out the crud and at the time, the compressor & clutch worked as expected.
Does the compressor run when in floor / defrost mode or just full defrost?
I typically keep my selector in floor / defrost mode. I know the compressor is cycling cuz when I checked this, the pipes change temperature and I can see a few bubbles in the sight glass as the compressor turns off. My compressor must be a real quiet one because I can not hear it clicking on and off.
If the compressor is allowed to run when in floor / defrost mode, I don't have anything to worry about. If it is only supposed to run when in full defrost, I have a problem. As I am sure most know, there is no relay for the compressor.. Everything goes through the AC amplifier.
EDIT: 2007 US hatchback
barryware is offline   Reply With Quote
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
A/C Broken On My 2010 5 DR HB ChilliwackGuy DIY / Maintenance / Service 15 07-14-2010 04:33 PM
Gas mileage and A/C Chaad32 General Yaris / Vitz Discussion 18 01-29-2009 04:31 PM
Easy Defrost A/c running fix billk General Yaris / Vitz Discussion 14 01-16-2009 08:53 PM
