Old 10-29-2011, 05:03 PM   #1
Nips
Nips's Avatar
Drives: BMW 3 Series M Sport
Who needs air vents
Hi Guys,
Today i fitted a GPS Speed limit and speed camera detector.
I looked at a few different option of products i wanted something that once you buy was cheap to update, but small enough to custom fit, so i went for the MY SPEED AURA, £129.99 + £10 per year for speed limit updates.
i hate having things on the dash or windscreen. Took a bit of modification to get it in and used a perspex sheet to cover the unit.
Its all set up so don't need to press any buttons, and to update the unit a have hard wired the cable behind the glove box so i can simply unplug the usb from the charger and plug it in the laptop to update it every few months
Here is the end result, what do you think?
Video
Nips is offline   Reply With Quote
Old 10-29-2011, 05:10 PM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
That looks very clean.
Old 10-29-2011, 05:11 PM   #3
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
awesome!
Old 10-30-2011, 04:42 AM   #4
Nips
Nips's Avatar
Thanks for the nice comments guys
Old 10-30-2011, 04:49 AM   #5
barebonedvitz
return of the comeback
barebonedvitz's Avatar
Drives: white '08LB..very nice,i like
i just wet myself... lol
Everything will be ok in the end... if it's not ok, it's not the end.
93 Civic Si- SC/B18B1 - street beast
07 Red/BlackTop Yaris LB - died in a sandwich in 2010@168K.
08 White Yaris LB - daily beatnut...round 2!
barebonedvitz is offline   Reply With Quote
Old 10-30-2011, 04:55 AM   #6
Nips
Nips's Avatar
lol, i nearly spat my coffee all over my mac reading that
Old 10-30-2011, 03:38 PM   #7
barebonedvitz
hahaha! do u have a DIY on this? makes me wanna do it on my other cars now.. lol
Old 10-30-2011, 01:16 PM   #8
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
that is awesome, good job
-Derrick-
Old 10-30-2011, 04:17 PM   #9
Nips
Nips's Avatar
Every car will be different in terms of where you will put the unit, its a simply hard wire with a 12v charger behind the dash so it comes on/off with the ignition.
You would need one of these for charging
http://www.ebay.co.uk/itm/12v-Female...ht_2329wt_1378
Old 10-31-2011, 12:06 AM   #10
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
It looks so clean!
I also envy your bue rings around the Climate Controls
Old 10-31-2011, 03:16 AM   #11
barebonedvitz
when you said you have it wired so you don't have to press any buttons.. did you mean on/off or were there other operations with the other button
Old 10-31-2011, 12:16 AM   #12
solarVitz
solarVitz's Avatar
Drives: 08 Yaris S Liftback
Nice. is it just me or the speed of the gps speed limit doesnt match the speedometer reading? i think it is off by 4-5 miles short?
Old 10-31-2011, 05:34 AM   #13
ilikerice
ilikerice's Avatar
your looking at the RPM.. its at idle about 1800 rpms going 0 mph
-Derrick-
Old 10-31-2011, 06:56 AM   #14
CAyaris
CAyaris's Avatar
Drives: 2008 Toyota Yaris Sedan
Send a message via MSN to CAyaris
1800 at 0mph!!!!! WOW. I think you meant 800 lol
108hp and still rolling
CAyaris is offline   Reply With Quote
Old 10-31-2011, 12:24 PM   #15
ilikerice
ilikerice's Avatar
lol. yes.. i meant 800... where did that 1 come from? good catch.. thanks
-Derrick-
Old 10-31-2011, 12:10 PM   #16
That's a nice install.
Old 10-31-2011, 12:22 PM   #17
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
I'm not a fan, simply because it takes away the vent which is crucial where I live. I respect the work though, it came out great.
-Type 07 FFL-
My odometer 03/11
Old 11-01-2011, 02:34 AM   #18
Nips
Nips's Avatar
Thanks alot
It looks so clean!
Thanks man, get the blue done, its an easy mod
If your refering to the video then yes you are correct, All car speedos are out by around 10% so every 10mph you are out by 1mph, so if your doing 70mph on GPS you would be doing 77mph on the speedo. in the UK if your speeding Police have to give 10% + 1mph so in a 50mph you could do 56mph without being done for speeding. GPS is alot more accurate
there is other functions but ive set them up and will not need to alter then again, there is no battery in the unit so when the ignition is on the unit comes on and then when the car is turn off the unit goes off.
Thanks, Air con i guess as you live in cali. Well im from the uk so its cold most of the time i have the heater on 30 degress blowing on my feet and out every other vent. i have blocked the vent from the back so it just comes out the left vent quicker now.
