Old 12-01-2012, 03:04 PM   #1
bronsin
bronsin's Avatar
How To: Shift Your Car Without A Clutch!
This is using my 95 Chevy S-10 2.2 litre but you can adapt.
How to:
To start, shift into neutral when coming to a stop when in any gear. Take your foot off the gas. Dont use the clutch. You can do it as you stop or a few yards ahead of time your choise. This will demonstrate how simple and harmless it is. Practice it a few dozen times to see if clutchless shifting is for you!
To start its best not to be in traffic, be by yourself.
Drive the vehicle normally for a while to get the trans warmed up.
The upper gears are easiest to shift into sans clutch. At about 50 in 4th, let off the gas. Slowly but firmly, shift into fifth. It will feel a little rubberly but you shouldnt grind anything.
When you get good at 5th ,try 3rd into 4th. About 40 mph works for my 95 2.2. You may have to try other speeds with a six cylinder.
Now that you can do 4th and 5th, try going into 3rd from second. This will be harder, but easier than going to 2nd from 1st. Let off the gas around 25-30. Shift slowly but firmly. If it grinds try different speeds.
Now that you can do 5th 4th and 3rd go for 1st into second. This is harder than the others. Go about 15 mph. You might have to warm up the trans the first time you do it when its cold out. Or even in summer. Yeah rodger that drive around normally for a while before starting to clutchless shift.
You already know to start from a stop in first just crank the engine with the trans in 1st. Point the car downhill if possible or at least be on a level.
This is hard on the starter, obviously. But if your slave is out you CAN drive the vehicle using this method. Isnt that worth knowig how to do?
Ok now for the part that separates the men from the boys: downshifting!
Im going to give you a little easy thing to do which sounds hard but isnt:
Shift into first from second!
On my 2.2 this is never fail cant miss!. From 2nd or third shift into neutral while rolling towards a stop sign. Remember: be by yourself NOt in heavy traffic. Alone at midnite isnt a bad idea. Have the trans previously warmed up.
You are slowly rolling towards the stop sign in neutral. Use the brakes to slow to barely walking speed. I mean just creeping! Ease it in first. Goes every time for my 2.2! No grinding! No drama! Beautiful!
If it doesnt work youre going too fast. If you grind go into neutral, slow down and push it in again as the synchos mesh. You can feel it. Mine will go into first so slow you can easily run a stop sign in front of a cop and not get a ticket. Ive done it! I know you dont believe it but its true I swear! This is in NJ however where NO ONE stops for stop signs!
I dont know about down South. Maybe not!
Now you got to try the other gears. In all of them, you want to blip the throttle first. In shifting DOWN you want to be going slower than you went shifting UP.
5th to 4th ~35 mph
4th to 3rd 25-30 mph
3rd to 2nd 15 mph
2nd to 1st barely moving to 3 mph.
Once you can downsift clutchless you have arrived! You are a real Mamby Jamber! Your shit does not stink! You have chops few others have! This gets INSTNT respect from your guy friends.
Now...if you are a WOMAN be a little carefull with this before trying it out in front of a man. Especially the BF! You dont want to cut his nuts off. Which might happen in some circumstances! Be gentle!
After you get really GOOD at it its time for your
FINAL EXAMINATION.
This is rare but it DOES happen. Your best friend lets you drive is $150,000 PORSCHE! A Corvette is not as desireable but it counts.
My advice: make sure they arent carrying.
There are two ways to go about it. One is the ahead of time announcement. This takes conjones. You may also get sucker punched but just go with it. On the other hand, once in a while they may say: Go ahead I do it all the time. Big deal!
Another way if you want to be covert is just do it without saying anything. If they dont notice consider screwing his old lady because they obviously dont care about what happens to their personal possessions. Probably they WILL notice if they care about their car, but ignore any protests. You are more of a man then they are and they KNOW it!
Help! Lots to explain, look inside!! Car won't shift out of park and more! sasquatch DIY / Maintenance / Service 6 03-03-2012 05:05 PM
TWM Performance weighted shift knobs on sale! TWM Performance TWM Performance 5 06-30-2009 10:58 AM
Photo-Scavenger Hunt - THE LIST Black Yaris Photo-Video-Media Gallery 22 03-04-2009 09:35 PM
YAR1S - Photo Scavenger Hunt! YAR1S Photo-Video-Media Gallery 4 03-02-2009 08:44 PM
thewifesyaris - photo scavenger hunt thewifesyaris Photo-Video-Media Gallery 0 03-01-2009 07:02 PM
