Old 12-23-2013, 07:39 PM   #1
jn3825
Drives: 2012 Yaris sedan
Way through 2012 sedan firewall?
Is there a decent spot to get through the firewall on a 2012 sedan? I was trying to find one that i didn't need to drill but was unable to. Granted there was 8" of snow the night before and with the windchill at 5 degrees i didn't make the most thorough search but i did as much as i could from the top. Any help would be great.
I am trying to run a 4 gauge wire for an amp.
Thanks!!
jn3825 is offline   Reply With Quote
Old 12-23-2013, 07:52 PM   #2
Go through the giant grommet where the main harness runs through. If you look up behind the dash with your head by the brake pedal you will see it. The other end is right behind the battery.
Old 12-24-2013, 03:07 AM   #3
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Take a picture of the passenger side firewall and we'll circle it for you.
Old 01-11-2014, 02:12 PM   #4
sclary1999
Yargatti
Drives: 2010 Yaris Sedan
I went through the drivers door, no drilling required!
sclary1999 is offline   Reply With Quote
Old 01-11-2014, 02:58 PM   #5
400 dollar yaris
400 dollar yaris's Avatar
Drives: 2007 Yaris sedan
On my 2007 yaris sedan I looked for the factory hole behind the glove box , but for some reason wasn't there so I drilled a hole behind the glove box and ran wires down through the plastic pieces along the inside of the car under the door sills to the trunk where my amp is . Also did the same with the speaker wires and ignition wires because if you run them on the same side of the car it can cause interference.
400 dollar yaris is offline   Reply With Quote
Sedan speculation: 2012 liftback photoshopped into sedan Kal-El Third Gen Yaris General Discussion 6 04-09-2011 12:38 AM
Yaris Sedan Vs. Yaris 4dr. hatch Meow General Yaris / Vitz Discussion 11 10-29-2006 03:11 PM
