Old 12-04-2014, 07:25 PM   #1
trx680
Drives: 2008 Yaris 4 door
VALVE STEMS ???
I have an 07 yaris base model. Of course it has the low-tire-pressure alerting valve stems.
I had the tires replaced a couple years ago for the first time at a Merchants Tire, not sure what was done about the valve stems...never thought about it.
I need new tires again. How do these tire pressure alerting valve stems work? Is it a whole unit, or something that attaches to a replacement stem?
Someone fill me in
thanks!!!
trx680 is offline   Reply With Quote
Old 12-04-2014, 07:56 PM   #2
The Yaris did not get TPMS until 2008, so your 2007 does not have tire pressure sensors.
Old 12-04-2014, 08:00 PM   #3
trx680
sorry, wifes civic is a 2007
my yaris is a 2008
it does have the sensor. Light comes on when tire is low
Old 12-04-2014, 08:40 PM   #4
OK. In that case, to answer your question, the stem is part of the whole sensor assembly.
If you just replace the tires, then the sensors are fine. The seals between the sensor and wheel and stem and wheel should be replaced every once in a while (if memory serves me right it is about every 4 years) and tire shops typically stock the replacement seal kits.
Old 12-04-2014, 10:40 PM   #5
CoryM
Drives: 2009 5-door, 5-speed
Should replace the "sleeve kits" every time you get new tires (unless, like me, you change tires a LOT). Sleeve kits include: rubber seal, nut, core, cap and any tire shop should stock them.
Cheers.
VALVE ADJUSTMENT INTERVAL jemmah DIY / Maintenance / Service 7 10-12-2016 10:13 AM
Valve Noise barryware DIY / Maintenance / Service 25 02-13-2013 02:39 PM
Valve lifter Problem !!! Patocine DIY / Maintenance / Service 6 05-08-2012 11:09 AM
Ferrea valve upgrade kit cali yaris Micro Image 4 07-28-2010 11:52 AM
