Old 05-05-2009, 11:09 PM   #163
Yaris T-Sport.
Yaris T-Sport.'s Avatar
Drives: .
thats why I use a bigger hose clamp
Yaris T-Sport. is offline   Reply With Quote
Old 05-05-2009, 11:15 PM   #164
MGargano
Drives: 2009 Yaris Hatchback
It wasn't the width/diameter that was a problem, it was the length of the TB's neck that stuck out past the studs. It was barely wider than the hose clamp itself, so it kept slipping & popping off
Old 05-05-2009, 11:18 PM   #165
Yaris T-Sport.
Drives: .
maybe use a few zip ties?
Old 05-05-2009, 11:21 PM   #166
MGargano
lol that thought actually occurred to me as I was typing my previous post. Like I said, I haven't had any problems not having the clamp, but if I do I'll use a strong zip tie
Old 05-05-2009, 11:28 PM   #167
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
I guess ill just run in without the clamp and cross my fingers
Old 05-05-2009, 11:45 PM   #168
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
get 3 more bolts like the one lower left bolt and replace the 3 studs.
Old 05-06-2009, 12:16 AM   #169
PHXDEMON
PHXDEMON's Avatar
Just finished the install and holy fucking oscillation form 1000-3000 rpm from a cold start. I tried driving around a little bit and it started jumping up to 4k on idle and a CEL. How long does it typically take for the oscillation to start smoothing out? It's too late here (9:15) to mess around with it more. Don't want to piss off the neighbors. Any suggestions?
Old 05-06-2009, 12:20 AM   #170
MGargano
It took about 2 days or so for the oscillation & CEL to finally go away
Old 05-06-2009, 12:28 AM   #171
PHXDEMON
PHXDEMON's Avatar
I am doing to leave the battery disconnected overnight incase 2 hours wasnt enough.
Old 05-06-2009, 12:28 AM   #172
PHXDEMON
PHXDEMON's Avatar
Did the oscillation slowly smoothe out or did it just stop out of nowhere? How much driving did you do in 2 days?
Old 05-06-2009, 12:38 AM   #173
MGargano
I got oscillation at cold idle as well as intermittent CEL for the first two days, then both just went away completely. All I get now is the high (3,000 RPM) cold idle and better performance. I only did local driving during those first few days, no highway or any heavy pushing.
Old 05-06-2009, 01:14 AM   #174
PHXDEMON
PHXDEMON's Avatar
Damn I was still gettingm oscillation and my motor was getting pretty warm. Is there an an idiot light that turns on if it starts overheating?
Old 05-06-2009, 01:27 AM   #175
PHXDEMON
PHXDEMON's Avatar
WTF I just hooked the battery back up and started it up again and my idle was perfect with no oscillation Hopefully it stays that way. I didn't want to even take it around the block because I have had about half a beer and their are mad cops out for cinco de mayo. Hopefully I will have a nice drive to work tomorrow
Old 05-06-2009, 08:09 AM   #176
MGargano
Don't be surprised if the oscillation comes and goes for the first couple days. This happened to me and I thought everything was fine, then I got oscillation on the next cold start. Just be patient and give it a few days to work itself out.
Old 05-06-2009, 08:15 AM   #177
yarstar
Drives: 2008 Absolute Red HB
No clamp for months now on mine and no problems.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
Old 05-06-2009, 03:27 PM   #178
PHXDEMON
PHXDEMON's Avatar
Yeah it came back
Old 05-06-2009, 03:31 PM   #179
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
Just out of curiousity, are you guys doing the coolant bypass? I was considering doing so unless this changes the way it idles. The 3k cold starts for 1 minute is all I want as far as weird reving goes. Dont want the bypass to screw with my fine idling.
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 05-06-2009, 05:12 PM   #180
PHXDEMON
PHXDEMON's Avatar
I did do the coolant bypass. Drive to work today was great . I actually don't experience the high cold idle everyone else is. My cold idle is around 2k RPM just like stock. I did hower buy my TB from M911gt on here so he may have fine tuned the idle screw. I think if anything doing the coolant bypass will make it idle better
1.8L Engine Swap, Possible? Yaris T-Sport Performance Modifications 4 05-06-2007 06:57 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
