Old 10-08-2006, 06:35 PM   #1
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
Increased MPG or HP anyone????
Was curious if anyone was experiencing an increase in miles per gallon or horsepower with an aftermarket Intake or exhaust. I was curious to know if an intake or exhaust would benefit other then looking/sounding better. Let me know what you all are using and your thoughts on the product.
slvryaris is offline   Reply With Quote
Old 10-08-2006, 08:16 PM   #2
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Give me a couple of weeks and I'll let you know about the AEM cold air intake.
Old 10-08-2006, 08:32 PM   #3
Yaris TTE JWRC
Drives: 07 5spd red Yaris HB 1.5L 16V
if u increase th HP u are going to lose MPG, the same thing to Increse MPG = lose HP, u cant get it all, the Farrais only get 8-10 MPG, but the got mass HP. so if the intake give u good HP, then u will lose good MPG.
Yaris TTE JWRC is offline   Reply With Quote
Old 10-09-2006, 12:25 AM   #4
eco
eco's Avatar
Drives: 2007 Black Yaris sedan
Not so true Yaris TTe,I have a TRD CAI,And I noticed a 3-5% increase in milage,no bull.Actually if you are easy on the throttle at all times,you will get an improvment,but ofcourse when you get the CAI or exhaust,you always want to accelarate faster,because now you can.With the CAI,it actually is like compressed/denser air,which will cause your car to use less gas.zthink of it this way,if its real hot out side,air is less dense,so your car replaces lost air with more gas,so when the air is cooler via cold day or CAI system,them you will have better combustion using less gas,its that simple.As for exhaust,it helps reduce back pressure,and at the right rpm will increase the pulse performance,it like it creates a outward vacum that actually helps pull the exhaust out.If you have both CAI and intake,you will get good improvment if you are easy on the throttle,but can you resist when you get those new performance parts.And you cant compare a ferrari with a 4 banger,you dont even want me to start and explain why a ferrari uses more gas!!!
eco is offline   Reply With Quote
Old 10-09-2006, 12:29 AM   #5
Black Yaris
der Zeck
Black Yaris's Avatar
I have a TRD cold air and have noticed some MPG improvment, but, as eco stated, I romp on her a little bit more so it is only like 15-20 more miles per tank. hey even rompin on her hard I am gettin 30-33 MPG
Old 10-09-2006, 01:57 AM   #6
swng
swng's Avatar
Drives: 06 3-dr auto RS
When my OEM tires expire, I may buy a set of tires with lower rolling resistance and I believe I will get slightly better acceleration and slightly better fuel economy as a result.
swng is offline   Reply With Quote
Old 10-09-2006, 02:40 AM   #7
Yaris TTE JWRC
the bottom line, when u upgrade ur car with performance induction and exhaust system, it will take more fuel then the oem sysem, due to the INCREASE OF AIR FLOW, if u think ur CAI, SR, Header, or exhaust increases ur MPG, its all up in ur head.
Old 10-09-2006, 03:21 AM   #8
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
The only way adding an intake will decrease your mpg is if your busy gunning it all the time to hear the noise of it. When You add these bolt ons such as intake, header, exhaust, it only improves fuel efficiency. Adding more power to the vehicle only makes it easier for the vehicle to move itself. Meaning the engine has less struggle getting the car moving, and also means you are able to apply less gas to get to your desired speed at the right amount of time.
Yes you are adding more air into the engine which helps increase combustion, but you are not adding more fuel to it unless your running an aftermarket ecu. Adding an intake will not make your ecu send more fel into your engine to compensate for the "extra" air. It's set to what it is, and that's that.
If anything with all bolt-ons most cars end up running lean if they don't have an ecu to tune with because the factory ecu will not automatical ajust itself and send more fuel. While this is good for gas, going to lean is not good for the motor on the long run....especially if your always pushing it.
Yaris Mods:
20% Tints
Ground wires
2007 Toyota Yaris Liftback - Current
2004 Honda S2000 - Sold
1986 Toyota Corolla SR5 - Sold
DIY: Groundwire Kit
ItsMyDaily is offline   Reply With Quote
Old 10-09-2006, 03:24 AM   #9
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
and if you need an example.....
when I had my S bone stock I was averages with calm driving around 200-210 on a full tank. After adding my intake/header/test pipe/exhaust/flywheel I was making close to 230whp(this was all on the stock ecu). After all those mods I was averaging with calm driving 235-245 on a full tank.
Yaris Mods:
20% Tints
Ground wires
DIY: Groundwire Kit
Old 10-09-2006, 12:24 PM   #10
Violin
Violin's Avatar
Basic thermodynamics tells you that all other things being equal, when you lower the intake temp, you'll increase effeciency.
Old 10-13-2006, 11:26 PM   #11
jcove
jcove's Avatar
Drives: 2011 Rogue
I have just recieved my axle back exhaust from Vibrant. (I'll have pics up on the weekend) It was installed last Friday and I filled up Friday night. I was getting about 500 kms per tank of gas. Right now I have two bars left and I'm already over 450 kms on this tank. My thoughts are that if the engine is flowing better, your running at a lower RPM at the same speed. I've noticed about 500 rpm difference at highway speeds. That way you are using less fuel to go the same speed. Same goes with the intake. I LOVE the sound of my exhaust and it looks sweet.
jcove is offline   Reply With Quote
Old 10-13-2006, 11:34 PM   #12
riceboy
Drives: icebox
Hey Jcove, long time no see!!! Glad to see that you got things worked out with Vibrant, can't wait to see the pics!!! Hey let me know if you're coming out to the fall tour this Sunday....
riceboy is offline   Reply With Quote
Old 10-18-2006, 01:46 AM   #13
bulldogs2k
bulldogs2k's Avatar
Drives: '00 s2000, 2007 yaris hatch
I need to get a header and emanage! my goal is 230 to the wheels, but i want to get there with my cats still in place. I will probably buy a test pipe and put my exhaust back on for a quick dyno run.
Get the intake!
bulldogs2k is offline   Reply With Quote
Old 11-19-2006, 08:43 PM   #14
Ron
Drives: BBM Yaris HB
sorry to say, your thoughts are wrong. RPM and speed is dependent on the gearing of the transaxle. ie. if you are going 100km/h in 5th gear, your rpm will ALWAYS be the same. the ONLY way for any changes to affect your rpm-speed relation is if you change your overall wheel diameter.
yes, you may be using less fuel to go the same speed, which is why mods usually increase mileage, but it does not change the rpm-speed relation in any way.
Ron is offline   Reply With Quote
Old 11-19-2006, 10:43 PM   #15
eco
eco's Avatar
Your wrong Ron.Even when Im behind a trailer,I notice a diffrence in rpm's at a set speed.I have a ScangaugeII and a tach,I know what Im talking about.Laws are made to be broken,and I know for sure thats not a law.
Old 11-20-2006, 01:21 AM   #16
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
Wow there is gonna be a great debate here.
My yaris - gained some Hp with my new muffler, but i dont take that much notice with my MPG
Old 11-20-2006, 03:24 AM   #17
spkrman
Drives: 1
same here, small gain with muffler only, nothing measurable mpg wise though, if there is a difference its not big.
Old 11-20-2006, 06:11 AM   #18
hasher22
Look mum no stars!!
hasher22's Avatar
Ya its always good to get something out of your mods, emotionally or performance wise.
Like i always say "better than nothing"
New to Yaris ? Check in here !! VitzBoy General Yaris / Vitz Discussion 1956 08-17-2025 10:54 PM
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 07:41 PM
Synthetic oil MPG boost since change Yaris Dick General Yaris / Vitz Discussion 29 09-15-2007 09:15 PM
38 hwy miles per gallon, lol, you kiddin me? pennystocks General Yaris / Vitz Discussion 70 09-29-2006 09:13 PM
