Old 03-01-2007, 11:02 AM   #109
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Aw hell...I'm on board too.
This looks simple enough to do. Remebering my last vehicle, I would have paid someone to do this on that vehicle! The nice thing is our alternator and battery is right there and VERY easy to get to.
I'm still considering buying a stock alternator and sending it into Ohio Generators or to Dominick Iraggi to have them do a custom higher Ampere alternator.
Does anyone know the part # for our alternators and the stock output of these things?
― Thomas Paine
Old 03-09-2007, 08:07 AM   #110
luckydlb
Drives: 3dr Black Yaris Liftback
Originally Posted by bigsky2 View Post
Stock output of the alternator is 90A from what I can remember.
It will support a basic "non-threatening" sound system, but I think it cannot hold its own for more ambitious projects.
Do you think that this would be why my amp will shut off when it gets to loud, and my lights dimming with every hit?
luckydlb is offline   Reply With Quote
Old 03-09-2007, 05:27 PM   #111
Kitt
Kitt's Avatar
Drives: Thndr cl metallic HB 3 drs '05
Send a message via MSN to Kitt
Been there, done that: Add a capacitor and or replace the battery, get a bigger cable for the battery positive and problem solved, don't forget a good fuse...
20 years... alive and kickin'!!
Kitt is offline   Reply With Quote
Old 04-03-2007, 08:28 PM   #112
naossoan
Drives: 07 Yaris 3DR
What is the point of running so many ground wires?
naossoan is offline   Reply With Quote
Old 08-30-2007, 12:07 AM   #113
OgDogg
Gas Guzzler
OgDogg's Avatar
Drives: 07 Yaris Sedan S
I bought a red kit cuz it matches my other upgrades. :) I'll be interested to see if it provides any noticeable difference in the car's performance.
OgDogg is offline   Reply With Quote
Old 08-30-2007, 02:09 AM   #114
eijikikimaru
Q(','Q)
eijikikimaru's Avatar
Drives: 3dr Meteroite
OgDogg,
You may not notice improvements at all if you just randomly ground the wires.
IMO it's does wonders when you dyno test the ground wires so you can ground the wires at the best possible points.
Just a heads up because you maybe dissapointed when you don't feel/notice any improvements.
eijikikimaru is offline   Reply With Quote
Old 08-30-2007, 04:18 AM   #115
Edd
Drives: None
It makes your car go faster!
EDIT: In all seriousness though, if you draw more current, you will need less resistance in the wiring. Though this is somewhat debatable.
Edd is offline   Reply With Quote
Old 08-30-2007, 02:01 PM   #116
OgDogg
Gas Guzzler
OgDogg's Avatar
Originally Posted by eijikikimaru View Post
OgDogg,
I was just going to follow this DIY to install it. :) I'm more concerned with the looks and the constant shocks passengers get when getting out of my car. I'm hoping this grounding kit helps a little with that. Out here in the desert there is a ridiculous amount of static electricity, so we'll see if this helps at all. It could just be a pipe dream thinking this will have any effect.
Old 09-16-2007, 11:03 PM   #117
OgDogg
Gas Guzzler
OgDogg's Avatar
Well, I got an oil change today and decided to install my grounding kit when I got the car back. After taking my first ride here are my impressions. Might I also say that I was very skeptical that this would do anything for the performance.
It seemed like the rpms were much lower at cruising speeds than before which made it feel less like the car was struggling to maintain speed. It also felt much smoother shifting through the gears. No delay throwing it into the next gear. That was the most noticeable attribute. It could just be the oil change, but I doubt it. I recommend the grounding kit.
Old 09-17-2007, 05:21 PM   #118
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
Some one told me that modern cars are grounded pretty well because I really want this but i dont want to waste my money
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 09-17-2007, 05:48 PM   #119
BailOut
Steals terrorist's lunch
BailOut's Avatar
Originally Posted by KSIbucky View Post
i dont want to waste my mom
Translation?
- Brian
Share the Road
Old 09-17-2007, 05:48 PM   #120
KSIbucky
KSIbucky's Avatar
Translation?
sorry
7 Color Tach
Fujita Intake
Blitz exhaust
(Next is DC Header)
Old 09-17-2007, 08:57 PM   #121
OgDogg
Gas Guzzler
OgDogg's Avatar
Well, when upgrading a bottom end car such as the Yaris it's always going to be a waste of money. :) But if you want to slightly improve things and you enjoy working on your car, go for it!
Old 10-17-2009, 09:55 AM   #122
smartazawhipz
5-Speed love
Drives: red 08 liftback
I installed my kit today! Findings!
Ok, i've been into cars and electronics for years now, and I must say that after I installed the kit, I did notice a stronger "feel" to the acceleration than before. Also my transmission (manual), seems to again "feel" better, more accurate than before. I also have a radar detector that can measure my voltage, and I now run an average voltage of 14.3 volts, where as before, my car would run 13.9 volts. I believe because the negative electrons run more freely now throughout my vehicle, there is more of a balance between the stronger positive, and normally weaker negative power within the car to make all power using mechanics more efficient.
Moreover, a better electrical balance throughout the car. For $22.00 shipped, even it it's a facade, and my electrical readings incorrect, it just "feels" better.
Summary: GET IT, it's cheap, and I CAN see a difference with my volt meter!
smartazawhipz is offline   Reply With Quote
Old 04-14-2010, 06:35 PM   #123
captaincrunch
Chris
captaincrunch's Avatar
The grounding kit replaces your whole negative right?... So you have to have one of those wires on the starter?
captaincrunch is offline   Reply With Quote
Old 04-28-2010, 03:15 PM   #124
sternz
Drives: 08 Blazing Blue LB
Excellent DIY Thank you.
sternz is offline   Reply With Quote
Old 05-07-2010, 06:19 PM   #125
captaincrunch
Chris
diy guide said posted earlier said to keep the stock negative terminal how do you connect do did you connect the cable to the grounding kit?
Old 05-11-2010, 08:13 PM   #126
Richie836
Drives: 2010 3-Door Meteorite Metallic
For brand new car or broken in car?
I have a 2010 3-Door 4-speed auto with less then 500 miles.
I will order a groundwire kit this week.
Should I wait until after 1,000 miles (the break in period) or after the first oil change (5,000 miles) or should I install the ground wire kit as soon as possible?
I have the fuel saver magnet that covers your fuel line near the engine. That really works. I had it working with my late car (2004 Corolla S - 10 to 15 MPG extra city). So far, about the same increase MPG for my Yaris.
Richie836 is offline   Reply With Quote
For Sale: Lexus GS Parts - L-Tuned Body Kit, TRD Strut Tower bar, 18"StaggeredWheels. TRD_Yaris Items for Sale by private party 6 05-06-2010 06:43 PM
Is aftermarket HID kit legal (in NJ)? Jfoofoo Cosmetic Modifications (Exterior/Interior) 25 03-19-2009 02:05 PM
DIY KEYLESS ENTRY on Power Liftback? TC-LIFTBACK DIY / Maintenance / Service 0 08-23-2006 09:57 AM
Any front bumper/ hood stone chip issues? Where could I get Clear Bra kit? tifosi360 General Yaris / Vitz Discussion 9 08-07-2006 02:43 PM
