Thanks Trevor. I blocked off the valve cover breather hose with my thumb while monitoring FTs. The suction on my thumb got stronger and stronger. In this situation the STFT actually started to climb and the engine rpm started to drop as though it was starting to struggle. At that point I removed my thumb and the idle went back to normal.
With the breather line open and around 3000 rpm, the STFT drops to about +6 to +7, down from +18 - +19, but LTFT remains at around +29. I'm leaning toward the different plumbing - airflow pattern/volume etc - throwing the MAF off and as a result the FTs and I hope that the MAF clamping via the F/IC should solve, or at least improve the situation. A lean code P0171 was finally set although AFR's always remain around stoich (14.6 - 14.8, so it seems the ECU still had control of fueling) and never deviated from that, except when the throttle was let off and it dropped to 18:1, but that's normal fueling strategy - my 1nz does that too as did the 2ZR pre-turbo.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 06-02-2019 at 10:14 PM. |
| 3rd gen 2zr swap with 6 speed | stidnam | Performance Modifications | 97 | 06-29-2021 04:59 AM |
| Hyundai Turbo Veloster 150kw | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 6 | 01-09-2012 11:35 PM |
| ZPI Turbo for one lucky Yaris owner..... | ZPIracing | Forced Induction Forum | 27 | 04-26-2007 10:36 PM |
