Old 05-06-2007, 01:42 PM   #109
BokChoi
Mada Mada Dane...
BokChoi's Avatar
Drives: Toyota Yaris LB
just did the install today but im hearing a very high pitched noise. thought it was the brakes at first then i realized it was coming from something else. what did i do wrong?
My Car
My Garage
BokChoi is offline
Old 05-06-2007, 02:34 PM   #110
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
No idea. Doesn't mean its directly related to your spring install.
Only thing I can think of is, on the passenger side, when you removed the strut, did you let the spindle flop out and down away from the car's wheel well?
This happens sometime, but with our car, the shaft will pop out.. chances are it didnt happen, because you would notice a problem right away once you put the car in gear.
Chris07LB is offline
Old 05-06-2007, 03:24 PM   #111
BokChoi
Mada Mada Dane...
BokChoi's Avatar
could it be that i didnt firmly tighten the nut above the bushing. my bushings are seated a little bit above the metal, they were seated firmly on the metal with the stock springs. is this normal?
My Car
My Garage
BokChoi is offline
Old 05-06-2007, 03:54 PM   #112
Chris07LB
Chris07LB's Avatar
Thats normal after the spring install.
..... not the noise, the top cap space.
Old 05-06-2007, 05:46 PM   #113
BokChoi
Mada Mada Dane...
BokChoi's Avatar
ahhhhh what do you think i should do?
My Car
My Garage
BokChoi is offline
Old 05-06-2007, 05:58 PM   #114
Chris07LB
Chris07LB's Avatar
Well being none of us did the install, or are there to hear the noise, I dont know what to suggest to you.
Old 05-06-2007, 06:09 PM   #115
07typeS
07typeS's Avatar
Drives: 2007 White Toyota Yaris Type S
Send a message via AIM to 07typeS
That high pitched noise, is it a metal on metal sound? do you hear it constantly? do you hear it every 1 wheel rotation? do you hear it when the cars running only, or in gear as well? Some of those answers may help.
TRD Springs w/ KYB Struts and Shocks, Custom CAI w/ K&N filter and pre filter wrap, Weapon R Header, Stock 15 inch alloys, Dezod Performance pads, Tanabe Front Strut Bar, 35% front door Tint and 20% Rear doors back Tint, De-Badged Ass, Custom painted flat black interior, Pioneer deh-p6700bt w/ IPOD hookup, Infinity components up front with custom mounted tweeter, Inifinity 6x9's out back, 1 12" kicker comp cvr........
07typeS is offline
Old 05-06-2007, 06:25 PM   #116
BokChoi
Mada Mada Dane...
BokChoi's Avatar
i believe it is only coming from the passenger side. its a very high pitched squeak that happens when the car is moving slow either in drive or reverse. when i get to higher speeds the sound stops. i dont know how to describe the sound. it is very very high pitched and loud sounding almost like a car with bad power steering.
My Car
My Garage
BokChoi is offline
Old 05-06-2007, 06:39 PM   #117
Chris07LB
Chris07LB's Avatar
See if you bent your dust cover while working that side. You may have bent it just enough to be touching the rotor slighty.
Im thinking here... im thinking... hummm...
Your belts are all on the passenger side as well..
Old 05-06-2007, 06:48 PM   #118
BokChoi
Mada Mada Dane...
BokChoi's Avatar
ill have to wait until 2morrow to diagnose the problem, thanks for the info.
My Car
My Garage
BokChoi is offline
Old 05-07-2007, 08:24 PM   #119
BokChoi
Mada Mada Dane...
BokChoi's Avatar
problem fixed!!! the dust guard was rubbing against the rotor just as Chris had predicted!!!
THANK YOU SO MUCH!
My Car
My Garage
BokChoi is offline
Old 05-07-2007, 08:25 PM   #120
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
Chris is the MAN.
SPONSORED BY
brickhardmeat is offline
Old 05-08-2007, 07:10 AM   #121
Chris07LB
Chris07LB's Avatar
Glad to help, and glad it was something simple to fix.
Old 05-08-2007, 11:02 AM   #122
07typeS
07typeS's Avatar
glad you got it fixed. I had that same problem on my brothers older accord. It was just so old and the metal got so flimsy that I just took it off. It was a very annoying sound, that I do remember.
07typeS is offline
Old 05-13-2007, 04:56 PM   #123
Chance
Drives: Black SandPearl Sedan
DIY
Thanks, great instructions.
I used Sprint performance springs (claimed 1.75 inch drop) and the car actually rides better than before. I will post pic soon.
Chance is offline
Old 05-15-2007, 11:32 AM   #124
Slummy
Slummy's Avatar
Drives: Black LB
DIY was a great help. just a note' i found using a deep offset box end wrench worked very well for the removal of the strut tower bolt.
Thanks, B.
Slummy is offline
Old 05-15-2007, 11:53 AM   #125
MrJester
Drives: homo
I would agree with that if only I could find a shop that sold them I have checked everywhere around here. Freakin newbie I thought that would be an easy tool to find.
MrJester is offline
Old 05-17-2007, 09:12 PM   #126
YamilR
YamilR's Avatar
Let me recommend a craftsman set, lifetime warranty is a must and you have all the tools that you need. No complaints here
http://www.sears.com/sr/javasr/produ...cemldffidfno.0
YamilR is offline
Tanabe Strut Tower Bar Install & Review [pics!] Chris07LB Wheels, Tires and Suspension Forum sponsored by The Tire Rack 57 04-07-2022 08:46 AM
Springs - Tanabe DF210 or Tein S Tech andylai2k Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 06-10-2007 10:22 PM
Tanabe DF & Strutbar install mcdaddy DIY / Maintenance / Service 18 05-03-2007 10:57 PM
TANABE DF210 SPRINGS AVAILABLE!!! C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 08-05-2006 01:28 AM
Spring Install Price redglare45 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-30-2006 09:32 PM
