Old 09-21-2021, 12:43 AM   #145
Clawbrant
Drives: 2005 Subaru Forester
Originally Posted by Ben_ View Post
Does anyone have a backup of this PDF??? After 8 years of ownership I'm fed up of no cruise control
I second this. I thought I had a copy saved somewhere, but I can't find it.
Clawbrant is offline   Reply With Quote
Old 11-11-2021, 02:09 AM   #146
jeebeeg
Newbie
Drives: hilux
LS,
I have a problem to unpin the original cable from the earting connection on the airbag to the steering wheel.
I get the blocking plastic bit out, but cannot remove the pin from the housing.
And also I tried to download the manual pdf, http://tinyurl.com/CruiseDIY, but that does not work (anymore, or, just for me ?)
Help would be very much appreciated.
Jeebeeg
jeebeeg is offline   Reply With Quote
Old 04-17-2022, 09:49 PM   #147
Mrdea321
Drives: Vitz 2006
Link not working anymore please someone upload again thanks
Mrdea321 is offline   Reply With Quote
Old 06-11-2022, 11:33 AM   #148
Jithin_mp
Jithin
Drives: Yaris Sedan 2008
Dear TScott
Any idea cruise control work in Yaris 2008 DCC Yaris Sedan.
Hoping your valuable reply.
Jithin_mp is offline   Reply With Quote
Old 06-11-2022, 05:01 PM   #149
sh0rtlife
Originally Posted by Jithin_mp View Post
Dear TScott
i would be highly suspect if it didnt work and i say this as ive been thru the toyota cross referance part number catalog and basicly the same part is used for everything toyota from around 2004/05 till at the very least 2011 with some exceptions running significatly longer and some running shorter..specificaly design changes
Old 07-08-2022, 10:51 PM   #150
Evilthorne
Drives: Toyota MR2
Does anyone have the part number for the wires we run down the column to the ECM by chance?
Trying to get CC working on a cousins car before she drives across the country with it.
Evilthorne is offline   Reply With Quote
Old 07-20-2022, 07:24 PM   #151
Evilthorne
Drives: Toyota MR2
Does anyone have the pdf for installing this cruise control by chance?
Old 07-20-2022, 08:23 PM   #152
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Yes. It's about 10 Megabytes. I have put in on Google Drive here
Old 12-28-2022, 08:20 PM   #153
Don mullanix
Drives: Toyota yaris 07
How can i get this cruise control guide for toyota yaris
Don mullanix is offline   Reply With Quote
Old 12-29-2022, 01:25 AM   #154
sh0rtlife
the link in the post above yours is still good...
Old 04-16-2023, 05:54 PM   #155
matt4x4
Drives: 2008 Yaris, 4dr sedan, 5 spd
Nice that I found this, looks easy enough.
Long road trips the cruise on my '08 manual, sedan w/power will come in handy, just worried about any loss of power on the hills with the 1.5L, drove a bit into the mtns through the hwy1 hills a little bit into the rockies (Banff/Nakiska/back road hwy 40) back to the big city, and I had to downshift sometimes, just day 3 driving the cutie Yaris. I still need to fine tune the rpm gear change on the manual, I go by sound of rpms, but am in it for fuel sipping.
Link worked for me
Thanks
matt4x4 is offline   Reply With Quote
Old 04-16-2023, 05:56 PM   #156
sh0rtlife
i know with an auto running the coastal range it will downshift and handle it just fine..with a manual your kinda on your own there as to wen to downshift and pop out of cruise
Old 05-28-2023, 11:00 AM   #157
hypersata
Drives: Yaris 2014 GCC LHD 4AT
Hello there,
can anyone help me with the Aftermarket kit for Yaris 2014 GCC - Cruise control?
I cant find something useful on the internet myself.
as I discover from this forum, GCC versions are not supporting OEM CC.
any help would be much-appreciated Folks.
For the reference
NCP151L-CEPRKV
MHFBW9F36F50027xx
2NZFE 1300CC 16-VALVE DOHC EFI
hypersata is offline   Reply With Quote
Old 07-19-2023, 03:01 PM   #158
En4sir
En4sir's Avatar
Drives: '09 Yaris 3dr HB 5sp
I have a 2009 Yaris 2 door hatchback with a 5-speed trans. It has factory installed cruise control and 332,000 miles on the odometer. The cruise control recently stopped working. I've tried to activate the CC however the yellow CC light in the instrument cluster does not illuminate, nor will the CC operate. Hoping the culprit was a blown fuse I inspected all fuses - all seem fine. Then, hoping it was the CC stalk (hoped that the switch wore-out) I replaced the stalk with a brand new OEM stalk #84632-08021 Speed Control Switch. The CC still doesn't operate. I checked the original stalk with a multi-meter and the original stalk has continuous power while the stalk button is kept pressed in, but as soon as I remove all pressure off the button continuous power is disconnected. I assume that's how the on/off button in the stalk is supposed to operate(?).
I'd really like to get the CC operational again. What should be next course of action? I suspect that even if either CC disengage switch on the clutch and brake pedals are faulty, the CC indicator light on the instrument cluster would still light up. Is there a relay that powers the CC? Again, the yellow CC indicator light on the center instrument cluster does not illuminate. Other than the CC not being functional, everything else works flawlessly. Bad relay? Bad ECM? Or?...... Any advice that you may provide to restore my CC is greatly appreciated.
"Never argue with an idiot. They drag you down to their level, then beat you with experience."
En4sir is offline   Reply With Quote
Old 07-19-2023, 04:08 PM   #159
sh0rtlife
10-1 odds are its your snail AKA spiral cable, its actualy one of the hardest wearing parts on a car as your basicly bending wires back n forth every time you turn the wheel
9-10 times when a FACTORY CC fails it can be traced to 1 of 2 things, a bad spiral cable or a bad brake switch..and before you go and check if your brake lights work..remember that it has a secondary set of wires on the switch SPECIFIC to the cruise and not part of the brake lights
yet the first thing anyone replaces is the cruise stalk thinking its that....belive it or not ive yet to find one dead that wasnt physically visually damaged on the outside...fun side note is that said switch sometimes replacing it with other bad parts will give a false positive and youll have working cruise for a single use...its because you got lucky...i chased that demon earlier this year on an XB..intermitent CC working..was a combo of the spiral AND the brake switch both were intermitently bad
Old 07-22-2023, 02:38 PM   #160
Jithin_mp
Jithin
Thank you sh0rtlife. I have received all the necessary parts. I will give it a try. :)
Old 12-17-2023, 08:11 PM   #161
nickshch
Drives: Toyota Yaris 2011 AT LB
I have installed just the Cruise Control Switch to my Toyota Yaris 2011 Liftback AT (made in Japan, for US market) and that worked. Amazing! Thank you very much guys. Bought it on Amazon for $15
nickshch is offline   Reply With Quote
Old 02-17-2024, 06:56 PM   #162
steelwheels
Drives: 2010, 2 door hatch, MT
kevinj93 thank you so much for uploading the manual to google drive and sharing it on this forum I will now be installing CC in my '10 2dr mt hatch!! seems like all I need to buy is the clutch switch and the stalk. amazing.
here is the link to the file again just to make it super easy to find:
https://drive.google.com/file/d/1Bfc...fZXIDu7wL/view
steelwheels is offline   Reply With Quote
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 01:58 PM
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
