Old 10-12-2012, 04:22 PM   #37
Originally Posted by Setheroo View Post
Is there a reason to keep the buzzer hooked up? Is it the same buzzer for leaving the key in the ignition?
The buzzer is easily removable from the instrument cluster circuit board. The one buzzer is used for warning for seat belts, headlights, and key in ignition.
Old 06-06-2015, 08:51 PM   #38
townkat
Drives: Yaris '08
hi all,
i was just wondering, aren't the headlights already powered through a relay from factory? (or all the power go directly trough headlight switch ?)
if so can't we make the change directly there? without adding another relay? just by changing the command source?
btw i have an yaris d4d, automatic transmission, with keyless entry and start and digital dash and i love it
townkat is offline   Reply With Quote
Old 06-06-2015, 08:55 PM   #39
Originally Posted by townkat View Post
hi all,
i was just wondering, aren't the headlights already powered trough a relay from factory? (or all the power go directly trough headlight switch ?)
btw i have an yaris d4d, automatic transmision, with keyless entry and start and digital dash and i love it
They are controlled by a set of relays, but those relays are controlled by the headlight stalk. If you wanted to make the ignition control the headlights instead, then you could move the control point, but if you want the ignition to intercept that feed, as I did here, you need another relay.
Old 06-06-2015, 09:22 PM   #40
townkat
Drives: Yaris '08
so, headlight stalk control some relay, so there is little current going trough it
You really want a relay in there to keep the headlight and ignition circuits separate. The relay allows one circuit to switch the other, without being a direct connection.
if you can detail a little bit on this i would love to understand more, what can happen bad if relay is not used, as i am very tempted to wire them directly if i can't see a direct drawback
thank you
Old 06-08-2015, 01:58 PM   #41
shepd
Drives: 2007 Yaris 5 door RS
If you put more current through a switch than it can handle, typical failure modes include it becoming unreliable, it completely failing, the item physically disintegrating (due to arcing), and at worst, fire.
If a switch is meant to control a relay (likely less than .2 amps) and you place a 10 A current through it (what your headlights draw) I would lean to the end of the list (disintegrating or fire).
shepd is offline   Reply With Quote
Old 06-08-2015, 06:40 PM   #42
townkat
Drives: Yaris '08
i know that, but i understand that the headlights stalk just powers the command of some relays, so just few milliamperes ...
and my suggestion is to change the source of the headlights stalk switch, not its destination
anyway, thanks for the heads up, what you say it's true, just that i think it is not the case here..
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY: Yaris LB Halo Led Projector Headlights goku87 DIY / Maintenance / Service 37 11-15-2013 06:23 AM
need pinout of ignition switch mikenacarato In Car Entertainment + Electronics (audio / video / alarm) 8 12-25-2008 10:20 AM
Ignition switch heats up kurokoma-kun General Yaris / Vitz Discussion 11 06-19-2007 02:53 PM
