Old 03-13-2012, 08:17 PM   #73
auxmike
auxmike's Avatar
Check with Garm from Micro Image. He sells all kinds of Yaris extras.
Old 03-14-2012, 08:07 PM   #74
angelo6334
Drives: toyota yaris
Thanks for the reply. I will check!!!
angelo6334 is offline   Reply With Quote
Old 10-06-2013, 06:30 AM   #75
adeen
Drives: 08 Toyota Vios
Hi Guyz....Sry for digging up an old post but I need some help here....
Need some insight on installing the Esuse Fog Lamp...
Ive put the blue and green wire to the yellow and white wire....it does trigger the relay when my parking light is also on.
then the green and black to the green wire (at the AT shifter) and to the ground...
im having trouble at the A24 connector since pin 1 & 2 have already been used... i've tried the other pins and nothing seems to work...
what am I doing wrong? since my lights arent working
adeen is offline   Reply With Quote
Old 10-06-2013, 06:34 AM   #76
Is your Yaris a Japanese market or European market one? If you can PM me the VIN, I can check more of the details on how fogs would get installed on your car.
Old 10-06-2013, 06:38 AM   #77
adeen
mine is from the thailand factory....asian market.....it's a vios.....thanx for the quick reply
Old 10-06-2013, 07:08 AM   #78
adeen
pm'ed u already....thnx CTscott
Old 10-06-2013, 07:22 AM   #79
OK - Got your VIN. Your car is considered a "General" area car.
From what I see there should be another connector next to the one with the green wires that is a two row connector with 12 pins. That connector would be the one where pin 1 and 2 are the fog light pins. It may be a case where the cars which come with fog lights have that connector in the harness and those that don't do not.
Old 10-06-2013, 08:25 AM   #80
adeen
here's a car with fog lights in my area...the trd sportivo version....see the difference..?
so IYO, do u think my DIY can be salvaged?
Old 10-06-2013, 08:29 AM   #81
adeen
heres a full picture of the fuse block for the version with fog lights
Old 10-06-2013, 08:42 AM   #82
I think you will need to run the feed for the lights through the firewall.
Old 10-06-2013, 09:00 AM   #83
adeen
behind the relay in the cabin theres one yellow wire, two purple wires separately and two red wires in one socket...if i locate the red wire and connect the red wire from the fog light, would that suffice? i just want the fog light indicator to light up as it should
Old 10-06-2013, 09:28 AM   #84
Using that red wire would be fine.
I actually recommend following the DIY in the link below, which I created for Micro Image instead, as the one in this thread leaves the switching and illumination circuits bridged, which results in the light on the switch being illuminated, even when the car is off.
http://microimageonline.com/forums/s...n-Instructions
Old 10-06-2013, 10:12 AM   #85
adeen
ok thx a bunch...
Old 10-06-2013, 10:45 AM   #86
adeen
CTScott...what does pin 1 / pin 2 at the A24 Connector actually do? Does it trigger 12V when the fog light is on ?
Old 10-06-2013, 12:55 PM   #87
On the US market Yaris Pin 1 and 2 get fed 12V by the foglight relay when the switch is on.
On your car, that connector has a different designation than A24. I was thinking it was the same as the Japanese market Yaris, but seeing the three red wires in the position they are in, I now think your wiring is different than US and different than Japanese. I think you should measure the voltage on the pins the the locations of the 3 red wires with the fog light relay triggered on your car. I think you will find that either two of them (the two wires for the two front fog lights) or all three (which would also include the third wire for the rear fog light) will have 12 v on them.
Old 10-06-2013, 09:34 PM   #88
adeen
i've measured the green wires on the connector which gave out 0.04v when the headlights were turned on and 0v when it was off....
i've also measured the voltage on the three pins where the red wires are, and unfortunately no voltage on them...
seems like i need to work harder to get the fogs to light up....thnx for the input CTScott..
ill try opening up the fuse block and c what's underneath...
Old 10-06-2013, 09:44 PM   #89
OK. I would start from the other end (the wires leaving the fog light relay socket). The reds probably dead end at one of the junction connectors under the top of the dash.
Old 10-06-2013, 09:54 PM   #90
adeen
ok....i'll get to it as soon as i've got time to spare....i'll update any progress...
Fog light install 07yaris_fe Cosmetic Modifications (Exterior/Interior) 10 07-20-2010 01:18 PM
Looking for the Toyota Fog Light install RocknRollRon DIY / Maintenance / Service 33 06-13-2010 06:46 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
Before I start calling around: fog light install prices St_G Cosmetic Modifications (Exterior/Interior) 4 03-17-2007 09:45 AM
Finally installed oem ebay fog light for hatchback Adriaan General Yaris / Vitz Discussion 6 12-27-2006 04:24 PM
