Old 07-05-2010, 08:54 PM   #145
RedRide
RedRide's Avatar
Later models do no have the greenish-blue wire for the tach.
My '09 for example has a brownish wire for the tach.
Just use the wire that is in the correct position regardless of what the color might be.
Old 07-05-2010, 09:05 PM   #146
darkMINI
Drives: 08 hatch
WILCO, thanx
darkMINI is offline   Reply With Quote
Old 07-12-2010, 10:45 PM   #147
darkMINI
Drives: 08 hatch
Ok, next question, got the tach mounted and hooked up. Its an 8,000 rpm tach and it for reads perfectly up to 3,500rpm, but it for some reason won't budge any further. Ant ideas? Thanks
Old 07-13-2010, 01:13 AM   #148
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
Defect? Can you see any obstruction that would prevent the needle from moving?
5% Tint Rear | Micro Image LED Ignition Light Kit
fmicle is offline   Reply With Quote
Old 07-13-2010, 02:27 PM   #149
darkMINI
Drives: 08 hatch
I guess it could be a defect. I have everything hooked up except the Illumination wire, and I don't believe that matters.
Its a 4,6,8 cylinder model and the switch is set on 4.
Old 07-15-2010, 01:13 AM   #150
fmicle
fmicle's Avatar
Yeah, if it doesn't want to move past 3500 rpm, there must be something wrong inside...
Old 07-16-2010, 01:37 AM   #151
darkMINI
Drives: 08 hatch
Yep, went back to the auto parts store and borrowed a brand new one to compare it right in the parking lot. It turns out I had a bad tach, so they swapped me for the good one on the spot. Now I'm in business!
'08 3dr HB, Black Sand, AEM, 16x6.6 Mini-Cooper wheels, DynoMax, Cruise, de-TPMS'ed.
Old 07-16-2010, 01:45 AM   #152
fmicle
fmicle's Avatar
Haha, sounds familiar, I had the same problem with my tach, got a new one, worked fine, so I returned the bad one.
Old 07-16-2010, 02:01 PM   #153
RedRide
RedRide's Avatar
Glad you got it workin'.
Where did you mount your tach? Is is a panel mount or a pedestal mount?
Old 09-22-2010, 02:38 PM   #154
CueBall
Ruler of the free world
Drives: 09 Yaris 2D HB
Fmicle, did you mount your tach in the glovebox? I cant see the pics.
CueBall is offline   Reply With Quote
Old 09-22-2010, 02:42 PM   #155
sleey0
Drives: 2008 Yaris LB
Wish some company would come out with a nice A pillar guage pod already lol.
I am not a fan of drilling thru the driver's side compartment like that.
I suppose even using guage pedastals and drilling them into the A pillar would work (garm had a pic and he did this with his tc IIRC).
sleey0 is offline   Reply With Quote
Old 09-22-2010, 03:10 PM   #156
maxxman420
prop215.
maxxman420's Avatar
Drives: Toyota Yaris LB
i really need to do this. i have the same tach but in white. mine is just sitting where that johnson and johnson thing is sitting in the side cluster. haha
maxxman420 is offline   Reply With Quote
Old 09-23-2010, 01:13 AM   #157
fmicle
fmicle's Avatar
OK, try to click on the links directly...
http://public.blu.livefilestore.com/...720.jpg?psid=1
http://public.blu.livefilestore.com/...723.jpg?psid=1
http://public.blu.livefilestore.com/...724.jpg?psid=1
Old 10-12-2010, 10:41 PM   #158
RedRide
RedRide's Avatar
Originally Posted by suzu View Post
guys, i know that its great to get help in installing a tach. BUT i must say for some of the experienced stick sh. (manual) drivers, like myself, the tach is not necessary. i drive by hearing the engine and i can tell you it works perfectly OK. i am just curious....how many of you are actually gonna use the tach for the purpose of changing gears.
Granted, you can drive a car without a tach.
However, have you ever seen a race or performance car without one or ever heard of a race driver etc who does not insist on one?
Besides if you got your sys turned up, you can't hear the engine that well can you.
Anyway, one really does not use a tach for changing gears as a matter of routine. A tach is simply just one more way of monitoring an engine
BTW I have been driving a manual for the last 45 years!
Old 10-13-2010, 12:41 AM   #159
fmicle
fmicle's Avatar
Wow, that would make you at least 61 years old!
Old 10-14-2010, 02:01 PM   #160
RedRide
RedRide's Avatar
Actually, I am 63 years old!
Just abouit every car I ever owned was a manual because I enjoy going through the gears and driving in general.
BTW, my very first car was a '57 Chevy and my second one was a "55 Chevy. Back then, they were not yet considered classics. They were just cheap older cars
Old 10-15-2010, 12:14 PM   #161
metalshark
MetalShark
Tach dreamer update: I've finished the 33 LED analog display installed in the display trim similar to my earlier BS2 tach. Those of you from the LA basin may have seen the only operational prototype of the gen 1 tach. I've finished the firmware (with the help of Prallax.com forum members) on a breadboard for a digital readout. It's running in my Yaris today. I'm changing the 4x7 segment display from red to green. I had a setback learning to solder surface mount chips for the analog display.
I'll have to do a version 1.1 layout before it's kit ready. I love the headrest video camera mount I found here. When success is apparent watch for the video coming soon to a forum near you.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header.
metalshark is offline   Reply With Quote
Old 12-06-2010, 06:37 PM   #162
OTB
OTB's Avatar
Drives: 2zz MR-2 Spyder
Wiring question
A question for this installation....
Could you also tap the tach and illumination wires that plug into the main speedo panel? There is a tach signal even for cars without a tach display. I know becuase I plugged a canadian panel into an american liftback and the tach worked fine.
cheers
OTB is offline   Reply With Quote
Liftback Spoiler Installation Toddhata Cosmetic Modifications (Exterior/Interior) 25 08-09-2009 01:26 AM
