#199 |
![]() Drives: 09 Yaris 3drHatch Join Date: Aug 2013
No Tach reading
I Spliced the green wire into an orange wire that is on the far bottom left on the ecu port. I've read online that that was where I'm supposed to do it since I have tire pressure monitor. The orange wire is in replace of the greenish blue wire your talking about in cars with tire pressure monitor. It has been driving me crazy that it wont read rpms. Lights work and it has power, also I put my ground exactly where you have yours. Any Ideas?
Thx 09 Yaris3drhatch |
#200 | |
#201 |
I used the one that came with the kit. Is there any other way to splice the wires together? I'm just afraid now that the orange wire is basically in half once I remove that little plastic connector. Sorry I'm a noob when it comes to the wiring side of things.
#202 | |
#203 | |
For your 3rd generation French-built Yaris it is similar. The Tach wire is still in the same place on the diagnostic connector. The wire color may be light green or beige, but the position is the same: ![]() For ignition switched power, if you have a key (instead of the Smart Entry system) you will use the pink wire on the ignition switch connector. For ground you can use a bolt into metal under the dash, or any white wire with a black stripe. For illumination, it looks like your French Yaris does not have the dimmer rheostat for adjusting the brightness of the speedometer, so you would instead use the sky blue wire in pin 18 of the headlight switch connector. Pin 18 has a pink wire on one side of it and a violet wire on the other side of it.
#204 |
Drives: yaris 2007 Join Date: Mar 2015
de donde sacastes la seņal del rpm ? la puse en el cable azul y no me llega completa
#205 |
hello. so if anyone read through all this and still has questions, i'm going to post what I did, and tomorrow I will post pictures of my install:
first, I tapped into obdII plug, light green or brown wire, for tach signal, ground is at kick panel. those are great places. for my power I ran it to the 7.5A by itself by the 15A fuse in previous post pics. and for illumination I ran it to the "accessory lighting" fuse, another 7.5A fuse, in second position. it should be noted, and it was never mentioned, that if you go the fuse plug route, you should remove the fuse and test which side of the circuit is hot when energized. wire goes on the "ground" side of the fuse plug so the circuit is protected from added load. hot side can cause wire overload/fire condition. on my testing the side of the fuse closest to the driver's seat was the hot side, but I urge you to use a volt meter/test light for testing circuit. also when running ILLUM. wire to lighting circuit fuse it is not in the dimmer circuit but it is the "parking lights" circuit and remains constant, but not too bright to strain the eye.(imo) I like how if you crank the dimmer all the way down/off, the tach is the only lights! |
#206 |
#207 |
I made my own gauge pod using "Testors" contour putty and lots of sandpaper.
#208 | |
The pink wire on the ignition switch connector is switched power.
#209 |
I wired mine into the cig. lighter fuse.
#210 |
Eagle
Drives: 08 yaris 3-door manuel trans Join Date: May 2014
Thanks man. I got mine in today and if it wasn't for you I wouldn't know where to connect the tach wire.
#211 |
Eagle
To the original post of course.
#212 |
![]() Drives: 2000 Toyota Vitz, 1300 cc Join Date: Mar 2016
I want to install a tachometer in to 2000 vitz, can any one advice on one to buy.
#213 | |
![]() Drives: 2007 Yaris 2 door hatch manual Join Date: Mar 2016
#214 |
Thanks, Yaris friends. I am looking at aftermarket tachs - the '07, MT Hatch is so quiet that I occasionally kill it, or over-rev at a light, and I've driven stick for decades... I just didn't know where to get that RPM signal from. Now I do. Thanks!
#215 |
![]() Drives: yaris sedan 2011 Join Date: Oct 2016
Any body for me link to buy Tach device, my yaris 2011
#216 |
Thanks all! I drive an '07 stickshift hatch back Yaris. Problems: 1.The engine idles so quietly and smoothly that I cannot hear it, especially with the radio on. 2. Toyota electronically idles the car at around 450 RPM to save gas...
These problems cause me to occasionally over-rev when starting out in first gear, or kill the engine! I've driven stick for 50 years, have several stick shift vehicles, but when you have no tach, a silent engine and a very low factory set idle, an aftermarket tach is a requirment!! |
| Liftback Spoiler Installation | Toddhata | Cosmetic Modifications (Exterior/Interior) | 25 | 08-09-2009 01:26 AM |
