Old 10-19-2006, 09:28 PM   #1
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Tanabe Strut Tower Bar Install & Review [pics!]
Special thanks to John @ BulletProof for the super easy and fast transaction!
First, for the money and quality of the Tanabe Strut Bar, you can't go wrong.
Everything about the kit, is straight foward and a very simple design.
I choose to toss the included hardware for some 3/8" Grade 8 hardware instead. This consisted of two washers, a lock washer, bolt, and Nylock nut for each point of attachment. This also made the install much easier, as I was able to get longer bolts for the strut tower brackets, and come up from the bottom of the wheel well. The Nylock nuts give added insurance as they wont back off / loosen over time like whats included.
Install is a simple 30 minutes taking your time.
Tools needed;
1/4" drive rachet
3/8" drive rachet
Two 6" 1/4" extensions
14mm 1/4" socket
14mm 3/8" socket
14mm wrench
Remove wheels. The brackets simply bolt down into the existing two holes on top of each strut tower. Install bolts from wheel well, up into strut tower, and lock down the Tanabe bracket with a washer/lock washer/nylock nut. Repeat for other side. Using the 1/4 drive socket, extensions, and rachet here makes it easy to get around the spring & strut in the wheel well, while holding the top nut with the 14mm wrench.
Tighten all four bolts down tight, and install both wheels. Once the car is settled on even ground again, slip the tie bar into the brackets. You may need to make a few adjustments on the bar ends, to line it up correctly with the holes in the brackets. Once its where it needs to be, tighten using the 3/8" 14mm socket/rachet and wrench.
Finished! Go enjoy your new tighter feeling Yaris.
Old 10-19-2006, 10:23 PM   #2
YamilR
YamilR's Avatar
Drives: Absolutely Red Liftback
Send a message via Yahoo to YamilR
Good review... like usual
YamilR is offline   Reply With Quote
Old 10-19-2006, 11:10 PM   #3
ChinoCharles
Drives: LB
Chris, another sweet DIY. Looking forward to the review! Whats next for you in the mod department other than the headers?
Old 10-19-2006, 11:52 PM   #4
littlecarlove
Drives: Want a Yaris
STOOOPID question alert.
What does that bar do? Keep in mind I’m one of those rare guys that
has no idea which end of a screwdriver to hold. If this is something I
need can I have it installed rather inexpensively?
Hays
littlecarlove is offline   Reply With Quote
Old 10-20-2006, 12:17 AM   #5
riceboy
Drives: icebox
Hays,
It's there to color match with his springs. You can install it for free, if you do it yourself.. or drive to NJ and Chris might be able to help you out...
riceboy is offline   Reply With Quote
Old 10-20-2006, 12:44 AM   #6
DARKYARIS
Drives: 2007 Yaris RS HB
Excellent.......Now to find some Stainless Steel and fab up my own !!!
Where is the cover off the top of your engine ???? I changed the color on mine second day I had the car.
DARKYARIS is offline   Reply With Quote
Old 10-20-2006, 01:32 AM   #7
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
Nice dark, though just a curious question.....y red? i love red dont get me wrong, i just like your perspective on it :)
For me if i had a black yaris i woulda gone with yellow....lol...i wish i had a black yaris
Old 10-20-2006, 03:07 AM   #8
jmew0ng
Drives: Scion FRS
is the reason for such a large curve is just to avoid that terminal cover?
I was wanting to try an echo strut bar on the yaris but i forgot to take it off before trading in my car to find out >.<
Oh and lovely looking strutbar ;)
jmew0ng is offline   Reply With Quote
Old 10-20-2006, 03:56 AM   #9
DARKYARIS
MMMMMMMMM RED
Black just looks good in my eyes with a splash of Red for contrast.
I just like shiny RED things......Like my Scooter
Old 10-20-2006, 07:19 AM   #10
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Where'd you get the purple gloves?
Old 10-20-2006, 07:21 AM   #11
Looks good, much more visible than the Cusco bar which bends toward the back of the car, under the dash... and this one is well color-coordinated too!
Old 10-20-2006, 07:52 AM   #12
paultyler_82
Drives: 07 Meteorite Metallic Yaris LB
Hays
Front Strut Tower Bars like the Tanabe basically link the two strut towers structurally, it reduces chassis flex and transfers more of the roll in a turn, dive, or yaw to the struts, which can handle it more effectively than the frame of the car can, that translates to better handling characteristics.
They're just Nitrile gloves, look for em wherever you would find latex gloves, Wal Mart's got em in the section with the spraypaint and sandpaper.
paultyler_82 is offline   Reply With Quote
Old 10-20-2006, 08:38 AM   #13
Chris07LB
Chris07LB's Avatar
Few cool one off mods finishing soon..
Old 10-20-2006, 08:39 AM   #14
Chris07LB
Chris07LB's Avatar
Gimme your address, Ill send ya a box.
Old 10-20-2006, 08:41 AM   #15
Chris07LB
Chris07LB's Avatar
Thanks Paul, you nailed that answer better then I ever could!
If you didn't install your Tanabe Strut yet, send me your address, and Ill get you out the upgraded Grade 8 hardware. Whats included is a joke!
Old 10-20-2006, 08:42 AM   #16
Chris07LB
Chris07LB's Avatar
There is actually a LOT of room between the terminals and the strut, I know it looks rather close in the pictures though.
Old 10-20-2006, 09:43 AM   #17
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
I use the same purple gloves when I am workng on engines at Cummins.
slvryaris is offline   Reply With Quote
Old 10-20-2006, 11:44 AM   #18
Violin
Violin's Avatar
They do look a lot stronger than the painter's glove I get by the bagfull at Home Depot.
For Sale: Lexus GS Parts - L-Tuned Body Kit, TRD Strut Tower bar, 18"StaggeredWheels. TRD_Yaris Items for Sale by private party 6 05-06-2010 07:43 PM
2006-2007 Yaris 4 Door Front Strut Bar AEM/DC Sport KenAEM Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 02-22-2007 12:08 PM
2006-2007 Yaris 4 Door Front Strut Bar AEM/DC Sport KenAEM Performance Modifications 2 10-07-2006 03:26 AM
2006-2007 Yaris 4 Door Front Strut Bar AEM/DC Sport KenAEM General Yaris / Vitz Discussion 3 08-30-2006 10:43 PM
c one motorsport performance bars badhabitz Performance Modifications 17 08-23-2006 11:31 PM
