Old 04-09-2012, 01:57 PM   #11
CoryM
Drives: 2009 5-door, 5-speed
A suggestion to all owners, but specifically while doing this job:
Make sure your vent is clear as well. The transmission has a vent on it to allow for the expansion of the oil/air inside. Otherwise the seals have to deal with the pressure and will eventually fail. These vents often clog, and mine was plugged when I got the car with 38000km on it. A good indicator it is plugged is you will hear a hiss of air as you open the fill plug.
I can't recall exactly where the vent is on these cars. iirc it's just behind the shifter. A little white(?) plastic knob that you twist and wiggle a little to free up any junk.
I'll try to find a picture.
Cheers.
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 10:22 PM
Yaris Auto need help with tranny oil change chrisada_to2a General Yaris / Vitz Discussion 2 05-17-2007 02:51 PM
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 09:37 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 09:16 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-08-2006 12:21 AM
