der Zeck
Official YARIS Wheel & Tire Guide
WHEEL BOLT PATTERN PCD = 4 x 100mm
CENTRE BORE = 54.1mm OEM wheel sizes, offsets (ET), and tyre sizes (diameter in inches): 14x5, ET45, 175/65/14 = 23.0 15x5.5, ET45, 185/60/15 = 23.7 16x6, ET51, 195/50/16 = 23.7 17x6.5, ET51, 205/45/17 = 24.3 TRD Option 18x7.5, ET42, 215/35/18 = 23.9 With stock suspension, you may safely fit many tyres from 23.0 to 24.3, +/-3%. __________________________________________________ _______ Recommended offsets (ET) and tyre widths (mm): ET35+ = 175-185 ET38-ET40 = 175-195 ET42-ET45 = 195-205 ET45+ = up to 215 __________________________________________________ _______ Here is an excellent and easy to use wheel and tyre fitment guide: http://www.rimsntires.com/specs.jsp __________________________________________________ _______ Optional tyre sizes (diameter in inches): *Commonly recommended replacement sizes Fitment depends on wheel width, offset, and suspension mods. 175/65/14 = 23.0* 185/65/14 = 23.5* 195/65/14 = 24.0 195/60/14 = 23.2* 205/60/14 = 23.7* 215/60/14 = 24.2 175/65/15 = 24.0 185/60/15 = 23.7* 195/60/15 = 24.2* 195/55/15 = 23.4* 205/55/15 = 23.9* 195/50/15 = 22.7 205/50/15 = 23.1* (Most lowered applications) 215/50/15 = 23.5 225/50/15 = 23.9 195/50/16 = 23.7* 205/50/16 = 24.1* 215/50/16 = 24.5 195/55/16 = 24.4 205/45/16 = 23.2* (Most lowered applications) 225/45/16 = 23.9 205/45/17 = 24.3* 205/40/17 = 23.5* (Most lowered applications) 215/40/17 = 23.8 215/35/18 = 23.9* 225/35/18 = 24.2 205/40/18 = 24.4 __________________________________________________ ______ Staggered fitments: 1. Staggered offsets are common in Japan. These applications even out fitment front to rear and are purely for appearance. Tyre size generally remains constant front to rear. Staggered offsets preclude tyre rotation. Recommended maximum stagger is 10mm. Example: FR, ET45//RR, ET38 Example: FR, ET42//RR, ET35 2. Staggered tyre widths are less common, especially on front wheel drive cars. These applications even out front to rear fitment. They are not recommended for the track, but as an appearance option they are safe under normal driving conditions. Staggered tyre widths preclude tyre rotation. Example: FR 205/55/15//RR 225/50/15 Example: FR 205/50/16//RR 215/50/16 Example: FR 205/40/17//RR 215/40/17 3. Wheels spacers are another option to even out fitment front to rear. Maximum recommended rear spacer width is 10mm. Tyre rotation is still possible. Example: FR, ET42//RR, ET42 with 5-10mm spacer
Awesome! Now we have a place to refer people for those daily questions
Lurker supreme!
Here's a cut & paste from an Excel spreadsheet I made up a while ago to help determine various tire sizes. Both models' sizes are included (as there is a 3.41% difference in diameter from the base to the RS model!). This doesn't take into account the ratio between wheel widths and tire widths.
Base Model with 175/65/14: HTML Code:
Width Aspect Wheel Diameter Circumference Difference
(mm) (%) (in) (mm) (in) (mm) (in) (mm) (in) (%)
Orig. 175 65 14 583.10 22.957 1831.86 72.121 -- -- --
+1 185 55 15 584.50 23.012 1836.26 72.294 4.4 0.17 0.24%
185 60 15 603.00 23.740 1894.38 74.582 62.5 2.46 3.41%
195 55 15 595.50 23.445 1870.82 73.654 39.0 1.53 2.13%
195 50 15 576.00 22.677 1809.56 71.242 -22.3 -0.88 -1.22%
205 50 15 586.00 23.071 1840.97 72.479 9.1 0.36 0.50%
+2 195 45 16 581.90 22.909 1828.09 71.972 -3.8 -0.15 -0.21%
195 50 16 601.40 23.677 1889.35 74.384 57.5 2.26 3.14%
205 45 16 590.90 23.264 1856.37 73.085 24.5 0.96 1.34%
205 40 16 570.40 22.457 1791.96 70.550 -39.9 -1.57 -2.18%
+3 205 35 17 575.30 22.650 1807.36 71.156 -24.5 -0.96 -1.34%
215 30 17 560.80 22.079 1761.81 69.362 -70.1 -2.76 -3.82%
215 35 17 582.30 22.925 1829.35 72.022 -2.5 -0.10 -0.14%
225 35 18 614.70 24.201 1931.14 76.029 99.3 3.91 5.42%
225 30 17 566.80 22.315 1780.65 70.105 -51.2 -2.02 -2.80%
HTML Code:
Orig. 185 60 15 603.00 23.740 1894.38 74.582 -- -- --
+1 195 50 16 601.40 23.677 1889.35 74.384 -5.0 -0.20 -0.27%
195 55 16 620.90 24.445 1950.61 76.796 56.2 2.21 2.97%
205 50 16 611.40 24.071 1920.77 75.621 26.4 1.04 1.39%
205 45 16 590.90 23.264 1856.37 73.085 -38.0 -1.50 -2.01%
215 45 16 599.90 23.618 1884.64 74.198 -9.7 -0.38 -0.51%
+2 205 40 17 595.80 23.457 1871.76 73.691 -22.6 -0.89 -1.19%
205 45 17 616.30 24.264 1936.16 76.227 41.8 1.65 2.21%
215 40 17 603.80 23.772 1896.89 74.681 2.5 0.10 0.13%
215 35 17 582.30 22.925 1829.35 72.022 -65.0 -2.56 -3.43%
+3 205 35 18 600.70 23.650 1887.15 74.297 -7.2 -0.28 -0.38%
215 30 18 586.20 23.079 1841.60 72.504 -52.8 -2.08 -2.79%
215 35 18 607.70 23.925 1909.15 75.163 14.8 0.58 0.78%
225 35 18 614.70 24.201 1931.14 76.029 36.8 1.45 1.94%
225 30 18 592.20 23.315 1860.45 73.246 -33.9 -1.34 -1.79%
Wheel width to Tire width Ratios: HTML Code:
Tire Width Wheel Width in inches, and the wheel/tire ratio
mm inches 5 5.5 6 6.5 7 7.5 8
175 6.890 72.57% 79.83% 87.09% 94.34% -- -- --
185 7.283 68.65% 75.51% 82.38% 89.24% 96.11% -- --
195 7.677 65.13% 71.64% 78.15% 84.67% 91.18% 97.69% --
205 8.071 61.95% 68.15% 74.34% 80.54% 86.73% 92.93% 99.12%
215 8.465 59.07% 64.98% 70.88% 76.79% 82.70% 88.60% 94.51%
225 8.858 56.44% 62.09% 67.73% 73.38% 79.02% 84.67% 90.31%
235 9.252 54.04% 59.45% 64.85% 70.26% 75.66% 81.06% 86.47%
Z
2006 Red Blitzed RS 5-door Last edited by Doc Zaius; 04-16-2007 at 08:17 PM. Reason: added a new table... |
Now this is one gangster-ass thread... an instant classic.
Lurker supreme!
The fact that there's such a huge difference in circumference between the base model and the RS model (more than 3%) has always made me wonder... like if they have different speedometer gearings...?! Weird, isn't it? And since the base model has smaller tires, it should mean it can accelerate faster than an RS can!
2006 Red Blitzed RS 5-door |
![]() ![]() ![]() Drives: 07 YARIS HATCH 5 DOOR Join Date: Apr 2007
can't imagine a yaris with 20' wheel
Break'em off some.
[QUOTE=Doc Zaius;74847]The fact that there's such a huge difference in circumference between the base model and the RS model (more than 3%) has always made me wonder... like if they have different speedometer gearings...?QUOTE]
The speedos are not gear driven. I really doubt the calibrations are different. |
#8 | |
der Zeck
#9 | |
Lurker supreme!
I'll post a link so the people can download the spreadsheet if they want. I'll have to do it from home though b/c I'm firewalled at work!
2006 Red Blitzed RS 5-door Last edited by Doc Zaius; 04-13-2007 at 12:42 PM. Reason: verifed info... |
Lonesome Cowboy
Drives: 2007 WHITE HATCHBACK Join Date: Feb 2007
I love this, Heil the Tire Nazi!
SPONSORED BY
der Zeck
funny thing is, Ich spreche Deutsch!
#12 | |
What do you guys make of this?
#13 | |
Black Yaris- Nice thread, very helpful! I'll reference tire/wheel PM's here from now on. |
ncie thread!!! I love it!
-- Blen
http://www.360voice.com/tag/noobblenjar ![]() My Car http://www.yarisworld.com/forums/showthread.php?t=4245 My DJ www.PainlessWolf.com |
Lonesome Cowboy
nice Against your advice I did end up going with these for a 15X7 wheel.... Falken Ziex Ze 512 205/50R15 17.9Lbs. I almost went with these guys .... Falken Ziex Ze 512 225/50R15 20.1Lbs.
SPONSORED BY
![]() ![]() ![]() ![]() Drives: 2007 Black Yaris sedan Join Date: Sep 2006
This should be emailed to every new member,or better yet,a private message.
#17 | |
der Zeck
Lonesome Cowboy
I appreciate all the advice. Didn't go ignored.
SPONSORED BY
| Tamago's guide to ultimate yaris handling | Tamago | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 99 | 01-25-2026 12:51 PM |
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
