I ♥ Yaris
Drives: Black 08 LB MT & red 97 Miata Join Date: Oct 2008
I installed my DFs in the middle of February and noticed the back springs (maybe just the driver side, I can't tell for sure) creaked when I got out of my car. Well I figured they were just settling, and the creaking would go away but it never did. When researching my rear sway bar install I realized that there wasn't torque specs on the shock bolts on the springs DIY and I just tightened them without much thought. I figured maybe I tightened them too tight and it was that joint creaking. Well when I installed my sway bar, I torqued the nuts to the correct spec, but it's still creaking a week or so later. I hate it, it sounds like some old POS. Any one know why it's still creaking or what I can do about it?
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt. - Bertrand Russell |
![]() ![]() ![]() ![]() Drives: Yaris YR Join Date: Oct 2008
My Pedders springs creak abit when i get in and out of the car. Im not even heavy, lol. Must be pretty normal. I've had them on the car for about a year or so.
![]() Mods: 17x7 ANZ Tazer Wheels with 215/40/17 Marangoni Tyres | AFE Air Intake System | NST Short Shifter Kit | NST Shifter Cable Bushing Kit | NST 10% Underdrive Crank Pulley | Pedders Sports Springs | Custom 2inch Cat-Back Walker Muffler with 2.5inch Xforce Twin Stainless Steel Tip | RS Side Skirts | RS Euro Spoiler | YRX Front Lip Spoiler | TRD Style Front Grill | 12mm Rear Hub Spacers | Ultra Racing 23mm Rear Sway Bar |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
You sure it's not your bushings? they are now at a different angle than stock and will 'travel' more.....I usually just spray mine with silicone spray (NOT PB BLASTER) and it kills the noise for a month or two....
MicroImageonline forums - Shroomster Xda Forums - Shroomster Androidforums - Shroomster I'm noticing a pattern...... |
I ♥ Yaris
errr bushings? no I'm not sure... That's the inserts in the ends of the shocks that the bolts go through right? The cars only 9 moths old, why would the bushings creak?
Like previously stated spray silicone lubricant on various spots in the rear suspension until it stops. could just be something with a little bit of surface rust.
btw, when you remove a bolt from the car. lub it. If you removed it once, chances you will do it a 2nd time. so you really don't want it to seized up.
| Bump stop length for drop springs. | PetersRedYaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 19 | 02-17-2010 09:37 AM |
| TRD Springs Vs Tanabe DF210...The Title Bout | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 47 | 05-23-2009 11:02 PM |
| Which lowering springs should I choose? | Danish Yaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 40 | 03-28-2009 06:56 PM |
| What springs should I get? Help! | CtrlAltDefeat | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 01-26-2009 07:32 PM |
| Tein Basic Damper Coliey's Vs. Tein S. Tech Springs | ToTo | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 35 | 05-07-2007 06:08 PM |
