Old 09-16-2006, 03:46 PM   #1
boxerboy
Drives: WRX ,Tacoma and Yaris
mileage getting better
I have 2000 miles on my Yaris hatch. The mileage is getting better. First tank was about 34 mpg, my last tank was 36mpg. This is around town and mostly short trips ( less than 10 miles), also ac on most of the time.
"PERCEPTION IS SELECTION"
boxerboy is offline   Reply With Quote
Old 09-16-2006, 04:21 PM   #2
ketel0ne
ketel0ne's Avatar
Drives: 2007 Liftback Blazing Blue
My break in point seemed to end at about 4k miles. change to synthetic oil at your 5k mile oil change. Inflate your tires to sidewall pressures.
ketel0ne is offline   Reply With Quote
Old 09-17-2006, 12:31 AM   #3
Lafiro
Drives: 06 Yaris Sedan
ugh
And mine just keep getting worse.... passing 8000 miles on it now.
Instead of the increasin miles at start, from 33 to 26 myself, today I was scared to see at 140miles the tank is half way..... usually its 180-210 before it indicates that... wtf is going on, all my tires are fine, and I didnt add anything in the past few gas tanks....
Old 09-17-2006, 12:44 AM   #4
ketel0ne
ketel0ne's Avatar
Over 62mph and the mpg plummets. Synthetic oil helps a bit. Examine your driving style and maybe invest in a scangauge.
Old 09-17-2006, 06:32 PM   #5
ScottFern
Drives: 2007 Yaris Sedan
I am curious how did you figure this out? Hmmm, I was under the assumption if I was cruising on the highways doing 70mph I would be safe to keep the good
mileage, but you say no?
ScottFern is offline   Reply With Quote
Old 09-17-2006, 08:01 PM   #6
ketel0ne
ketel0ne's Avatar
Scangauge has mpg and spd as well as 2 other settings on the same screen. It starts going down at about 52-53mph at 62 it just drops all the way off. To hold the yaris at 63-65mph you are getting like 28-32mpg. At 55mph the yaris is getting about 42mpg. This is in the automatic the manual may be different. At 60mph it is only turning 2600rpm. Cruise control would smooth this out a bit as well.
Old 09-17-2006, 01:43 PM   #7
ECHOKnight2000
Small Car Lover
ECHOKnight2000's Avatar
Drives: A Super Car
Also remember extra stuff in the car reduces mileage (weight), roof rack of any kind reduces mileage (drag), having your windows open (more so at high speeds like highway kills mileage), keep a consistant speed as possible, also remember short trips where the engine doesn't fully warm up effects mileage. Just food for thought! Hope it gets better!
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will.
ECHOKnight2000 is offline   Reply With Quote
Old 09-17-2006, 03:12 PM   #8
stuffy
stuffy's Avatar
Drives: 06 yaris 5-dr le man
ugh
seeing as you live in nyc, i'm assuming you probably spend a lot of time in traffic, idling at stop lights, etc., as echoknight suggests, short trips are a killer for fuel economy.
if you have manual trans, try shutting the engine off and coasting in neutral to stop lights that you know to be long.
stuffy is offline   Reply With Quote
Old 09-17-2006, 10:14 PM   #9
Lafiro
Hrmm
Most of this tank has been with a passenger/lots of high rev's/70-110mph driving. And yes I have been driving in the street a lot more then highway this tank aswell. Top that off, I had a flat tire that I was on for who knows how long. My tires are basically run flat tires. But they were pretty low, only had like 5psi in them... Maybe that also was the reason why.....
And I have too much junk in the car aswell that I have to get rid off. I will wait till this tank is done, refill, empty the car out of all its junk(except my system), and drive at the most of 65mph for the whole tank and I will let you all know what I get again next week.(I say this cause this week will be almost all highway driving.)
Old 09-18-2006, 12:19 PM   #10
pxpaulx
Drives: Barcelona Red 5spd sedan
a 5psi DROP would adversely affect your mileage, let alone the tires only Having 5psi. i think it is safe to say if your tires were properly inflated the effect on your tires at that psi was probably like driving through a muddy swamp.
pxpaulx is offline   Reply With Quote
Old 09-17-2006, 03:36 PM   #11
dngz
dngz's Avatar
Drives: black yaris sedan
mines getting better too!
dngz is offline   Reply With Quote
Old 09-17-2006, 06:12 PM   #12
ketel0ne
ketel0ne's Avatar
Using ethanol 10% mixed could cause a drop as well. At some point we will have no choice.
Old 09-17-2006, 11:25 PM   #13
stuffy
stuffy's Avatar
70-110mph driving
yeah, this speed will kill your fuel efficiency, slowing down should improve it.
Old 09-18-2006, 01:03 AM   #14
mhero
Drives: Yaris 5Dr.
I got 14 km./litre
mhero is offline   Reply With Quote
Old 09-18-2006, 06:57 AM   #15
Pars
Drives: 07 Yaris Liftback
while driving on the high at 70mph-105mph on an engine that's already warmed up, I've been getting about 34.5mpg on a manual transmission.
Pars is offline   Reply With Quote
Old 09-18-2006, 07:20 AM   #16
argylesocks
Bears eat beets.
argylesocks's Avatar
Drives: Yaris LB
just got my best tank yet at 42.3mpg (US)
tires @ 44psi
highway: 55-60mph
city: lots of neutral coasting
dont use the A/C
ill switch to synthetic oil at my next oil change...
Free veggie starter kit!
argylesocks is offline   Reply With Quote
Old 09-18-2006, 09:30 AM   #17
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Drives: 09 Yaris LE, H/B, auto
tires @ 44psi
highway: 55-60mph
dont use the A/C
You get better mileage is you coast in gear
The early bird gets the worm, but the second mouse gets the cheese.
07WYarisRS is offline   Reply With Quote
Old 09-18-2006, 09:40 AM   #18
ketel0ne
ketel0ne's Avatar
In the automatic coasting in neutral alleviates the drag from the trans when in gear. Allows for a higher coasting speed. The length of coast is extended as well.
On my 5spd Geo I always coasted in neutral, and the results were higher as well. The scangauge shows this instantly.
The rpms of both cars drop below 700 in neutral.
Fuel Economy Poll pennystocks Fuel Economy Forum 42 01-28-2013 12:10 PM
Gas mileage and A/C Chaad32 General Yaris / Vitz Discussion 18 01-29-2009 04:31 PM
Tired of poor gas mileage & buying premium gas. Boosted Peon New YARIS Purchase Forum 29 08-25-2006 08:59 PM
Excel gas mileage calculator AlexK General Yaris / Vitz Discussion 1 08-13-2006 11:42 PM
