Old 08-06-2009, 10:58 PM   #1
GreenSpeed
Drives: '08 Yaris LB
Pretty happy with new Tach
I know a lot of you don't like larger gauges, but I was looking for something larger than a standard 2 incher and there is not a great selection until you get to the 5 inch units. Let me also state that I would not have normally chosen a 10K tach for obvious reasons, but the specific guage I finally settled on only came as what you see in the bid I won.
This guage comes from MST and I found out too late that they do offer lower rpm units including dual faces models with RPM and boost pressure for the forced induction guys.
I like the fact that it is needle-less and the floating LED display is pretty eye catching. The gauge comes with software and can be fully programmed from a PC and it even has touch screen capability for setting rev parameters on the fly.
I'm a little dissapointed that my 08 LB revs out at around 3.5K (is that an improper reading?) from idle. At 80MPH in 5th gear, I'm barely cresting 2K rpm.
I'm pleased with how the housing turned out. Finding a 5 inch gauge pod proved virtually impossible, so I went to Home Depot and picked up a 3 inch PVC sleeve for less than 2 bucks. One side fit perfectly with the gauge lip to where it barely moves when slid on and I cut the other side at an angle using a table saw and some nerves. Once I got the cut right, I sanded it all down and applied several coats of flat black automotive plastic paint.
See the following You-Tube Link for a video of it in action:
http://www.youtube.com/watch?v=SlXnKH6s2Ak
Flame away!!
GreenSpeed is offline   Reply With Quote
Old 08-06-2009, 11:04 PM   #2
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
hehe looks cool.
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 08-07-2009, 02:31 AM   #3
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
looks good bro !! well done !!
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 08-07-2009, 04:10 AM   #4
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Dam , that is BIG ,
but it does look good ,
Old 08-07-2009, 09:30 AM   #5
elijahsami
Drives: yaris hatch & sedan
Great mod love it
elijahsami is offline   Reply With Quote
Old 08-07-2009, 10:18 AM   #6
ChinoCharles
Drives: LB
YOU ARE SO LUCKY THIS ISN'T A HONDA FORUM.
Old 08-07-2009, 11:17 AM   #7
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
[QUOTE=GreenSpeed;364628]
The Yaris motor redlines (revs out) at 6500rpm's. are there settings on the back of the tach that allow you it to be compatable with 8,6,4 cylinder motors? If there is make sure it's on 4. Looks awsome!!
Installing Speedhut tach, need help! RedRide DIY / Maintenance / Service 2 07-05-2009 05:02 PM
need a 2" tach, like the cobalt from autometer severous01 Cosmetic Modifications (Exterior/Interior) 0 04-20-2009 09:55 PM
Installed Tach...Tach works, RADIO doesn't! 5spBlazer DIY / Maintenance / Service 17 08-06-2007 09:57 PM
How to install tach? charles nelson DIY / Maintenance / Service 1 08-04-2007 12:34 PM
Auto-Meter Silver Sport Comp Mini Tach ChinoCharles In Car Entertainment + Electronics (audio / video / alarm) 7 02-26-2007 06:14 PM
