Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > Yaris TS Talk
Old 04-27-2010, 05:02 PM   #1
colinr5779
Colin Richardson
Drives: Yaris Sr 1.8 Dual VVT-i
Oil light coming on and off
Any1 else have this problem at roundabouts or sharp turns?? and should i get it checked?
colinr5779 is offline   Reply With Quote
Old 04-27-2010, 10:39 PM   #2
yarrr
Drives: 07 sedan
get it checked. In the US anyways, by the time an oil light comes on your engine is a goner.
yarrr is offline   Reply With Quote
Old 04-28-2010, 12:35 AM   #3
YarisSedan
Drives: 08 Yaris Sedan
If your oil light is coming on on corners it means you only have about quart or less of oil left in the engine. As you turn the little bit of oil swishes around in the pan and the sensor is uncovered with oil for a bit and light comes on. As car levels out oil does and sensor turns light off again.
Id check your oil level first. More than likely your oil change is past due. Or your leaking oil.
Old 04-29-2010, 03:06 AM   #4
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
thats oil surge , make sure it filled up :-)
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 04-30-2010, 04:38 AM   #5
G6-R
Drives: CHR 1.8 Hybrid + Yaris gen3
fill it up to max inmeditly
G6-R is offline   Reply With Quote
Old 04-30-2010, 01:11 PM   #6
colinr5779
Colin Richardson
its filled... 2ltr of mobil super fe 5w-30 semi.. scared ive fucked my engine now lol im a para case :(
Old 04-30-2010, 08:01 PM   #7
Only if you keep driving. I've had the light come on several times, haven't hurt a motor yet.
