![]() Drives: 2010 Yaris Sedan Join Date: Jul 2010
What's the best window cleaner? I'm frustrated....
I don't know about other Yaris owners, but no matter how many times I wash, dry, scrub, etc. my windshield and mirrors, they end up extremely spotty and/or dirty a day or two later.
I've researched various products and stopped using Windex because I heard that wasn't good. I started using "Invisible Glass," which doesn't really do much either and was also told to try Rain-X glass cleaner spray which I'm afraid to waste money on. My biggest gripe is the corners of the windshield(the parts the wipers can't reach) and my driver's side mirror. Both constantly get spotty on me. Any suggestions? |
Invisible glass works for me. Somehow I think you aren't getting all the water during the dry process. If you haven't got a way to get the water not seen in the cracks and crevices, it will find its way out onto those areas you dried. Even so, a shot of Invisible glass with a Microfiber should erase the spots.
![]() ![]() Drives: 2010 4D Sedan 5M w/convenience Join Date: Apr 2011
+1 Invisible glass
#4 | |
Removing water spots from auto glass
#5 | |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
Bob
Drives: Yaris and Scion XD 5 spd BSP Join Date: Dec 2009
When I detail mine, or any car, I also buff the glass and I do it AGRESSIVELY ! After that, anytime I clean the glass I use Invisible Glass Cleaner (which leaves a waxlike surface) and the glass is Very, Very, easy to clean and with SUPERB results. There are never any water spots, and there is also no dull area where the wipers never pass over. IMHO it looks and acts like fresh-from-the-showroom glass. Always........
![]() ![]() Drives: 01 Toyota Echo Join Date: Oct 2010
If you want to see it, use invisible glass. You'll see the foam, if on a budget get some white vinegar as stated above.
Hooch Brewer-Shine Sipper
I use that stuff for tinted windows on the inside (where the tint is). Outside the best thing is the vinegar mixture with newspaper (no lint). We use that same mixture in the house, along with the newspapers. We recycle!
![]() ![]() Drives: Black XA not yaris but close Join Date: Jun 2009
I use the rainX spray. It goes pretty far. Don't buy the rainX wipes, they dry out.
I bought one of those "windshield wonders" from the as seen on tv aisle at target. It works really good except I get the sudden urge to run down the street yelling "Shamwow" |
![]() ![]() ![]() Drives: Scion FR-S 2013 Join Date: Aug 2010
I only use water in a spray and then dry with a microfiber and pulls a spectacular shine.
#11 | |
Right now I'm in the process of removing wax and going to go with Duragloss sealant. First gotta do some minor paint correction work with a polisher.
#13 | |
Bob
Aloha From Hawaii -bob |
#14 |
Any kind of hand rubbed wax should get the water spots off. I use the Safelite window cleaner for regular maintenance. They give you a free can when you get a new windshield put in, but you can buy some at their stores. That Sh*t works GOOD.
'08 3dr HB, Black Sand, AEM, 16x6.6 Mini-Cooper wheels, DynoMax, Cruise, de-TPMS'ed. |
#15 |
boydstir
use car wax works great every time i wax the inside of my windows also less fogging and moisture try it i think you will like it the vinegar 50 50 thing is for hard water spots works good old trick for boat users McGuires cleaner wax is the brand i live by let me know if it works for you
#16 |
![]() ![]() Drives: 2007 Join Date: Dec 2010
In a nut shell x Just Use The Stoners Window Cleaner with a MICROFIBER towel
and dry it appropriately. the window should look perfect afterwards. if you want to avoid any heavy sticking of dirt to the window you will need to put a layer of something down after your done cleaning it. The best Rain/Snow/Dirt Repellent = Aquapel. Will work 8 months. if there is any dirt that sticks after its application x an easy spot up clean will get rid of it. Certain NR Washes and Waxes can be applied to a window to generally get the same effect. Regardless though, your windows gonna need some kind of cleaning atleast every two weeks to a month. hope that helps. |
#17 |
#1 Lemming
Drives: Light Blue '08 Yaris Join Date: Mar 2010
Stoners Invisible Glass + Newspaper = WIN Works like a charm for me. I will be getting one of those corner reacher things for where the windshield meets the dash once it gets warm, too cold for hand detailing anyways.
As far as wax goes, I really like the Maguiers products. The clay bar works wonders. Once the snow and sub-zero temps go away, I plan on a full interior/exterior detail and I'll post pics and products used.
#18 |
![]() ![]() ![]() ![]() Drives: 2008 Yaris HB Join Date: Oct 2008
Stoners Invisible Glass works awsome......
Also you should try the glass polish located on this site www.griotsgarage.com Pretty much all I use,their products last a long time and work well and are safe. Stoners and Griots glass polish are the only two things I foudn that actually remove without effort the spots,glass will look better tahn it did when new. |
| DIY: Colibri Power Window Install | Taiyaki | DIY / Maintenance / Service | 15 | 04-28-2016 09:03 PM |
| Help: Rear Door Small Window Install | nick.dollimount | DIY / Maintenance / Service | 7 | 09-22-2010 02:22 PM |
| [REQUEST] Removing Front Bumper + Faulty Electric Window '04 Yaris | lufcfan | DIY / Maintenance / Service | 0 | 03-03-2010 06:29 PM |
| Express window for passenger | Stoln | Cosmetic Modifications (Exterior/Interior) | 1 | 10-30-2008 10:38 AM |
| Window Sticker | Stoln | General Yaris / Vitz Discussion | 10 | 07-14-2007 01:01 AM |
