Old 11-03-2010, 11:42 PM   #1
LA Yaris
Yaris323
LA Yaris's Avatar
TRUE OR FALSE ???
Is it true that the sedan gets more MPG then the HB ??
Also does a HB weigh more then the Sedan ??
Old 11-03-2010, 11:48 PM   #2
sickpuppy1
Drives: 2010 Yaris Sedan
No, I think the HB is lighter. The back end creates more drag, but the weight savings offset it. The sedan is 4 inch longer wheelbase and 16 inches overall longer, but only 35 pounds heavier+/-. The ride is better in the sedan too. Depends what your looking for. I get right around 40mpg with a 2010 sedan.
Old 11-03-2010, 11:57 PM   #3
LA Yaris
Yaris323
LA Yaris's Avatar
LB / MT 2290 lbs
LB / AT 2335 lbs
Sedan / MT 2288 lbs
Sedan / AT 2321 lbs
looks like the HB Weighs more. ( found this info. on the forum)
That must mean the sedan gets better MPG.
Old 11-04-2010, 10:06 AM   #4
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
i don't think that little of a weight difference will make much of a difference on gas mileage. More important will be the driver.
Colin Chapman disciple
Old 11-04-2010, 10:25 AM   #5
redglare45
redglare45's Avatar
Drives: 07 Sedan - 5 Speed Manual
Page 3 on this PDF from toyota gives the specs of the 2011's.
Weights and mileage estimates pretty much look like this:
3-Door Liftback – Manual
2311 lbs
29/36
3-Door Liftback – Auto
2355 lbs
29/35
5-Door Liftback – Manual
2320 lbs
29/36
5-Door Liftback – Auto
2364 lbs
29/35
Sedan – Manual
2313 lbs
29/36
Sedan – Auto
2346 lbs
29/35
redglare45 is offline   Reply With Quote
Old 11-07-2010, 01:28 AM   #6
computerlove87
The Fit is NO!
computerlove87's Avatar
Drives: '09 3DR "S"|'87 Caddy Brougham
Send a message via MSN to computerlove87
Diffusers might help the LB a little bit. I am surprised by those weight figures, you would think 2 extra doors plus the extra length would make the sedan a little heavier rather than a little lighter than the 3 door. In reading the specs I am also surprised to see the 5 door only weighs like 9 pounds more. I would think adding all those extra hinges and locks and window mechanisms would add more than that. Also, I think those weights are for the base models with no power anything, I wonder how power equipment would effect those figures.
My OTHER car
Please ignore the Ferrari
computerlove87 is offline   Reply With Quote
Old 11-07-2010, 06:45 AM   #7
nemelek
DWEED
nemelek's Avatar
I don't have the spec sheet any more from 2008 when I bought. The HB is taller (I like the head room) which could create more wind resistance.
NST TRUE Racing Tow Hooks NonStopTuning NonStopTuning 59 01-06-2010 01:45 AM
True or False? New USA Dollars *MAD DOG* Off-topic / Other Cars / Everything else Discussions 34 08-31-2009 08:49 PM
True of False.. a dealership in the US can order you a Yaris xed New YARIS Purchase Forum 16 09-21-2007 12:28 PM
the stories are true sanchez General Yaris / Vitz Discussion 2 11-07-2006 08:17 AM
True differences. Boonespeed General Yaris / Vitz Discussion 7 06-26-2006 08:51 PM
