![]() ![]() Drives: toyota yaris sedan Join Date: Sep 2010
Trunk Problems
Hi
I have a problem with my trunk when i open it it doesn't stay open it closes back down on me It doesn't open up completely on it's own Does anyone have the same problems Can anyone help me by telling me what to do Last edited by blacks; 02-24-2011 at 05:28 PM. |
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
I've never had that issue. You might check that nothing is dislodged/broken in the area of the hinges. Compare the left and right sides for differences. One spring rod may be disconnected or damaged.
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
I already checked all of that there's nothing broken or disconnected
![]() ![]() ![]() Drives: 08 2Dr LB Base, Silver Join Date: Jan 2011
Did you by any chance soundproofed it? Adding weight to the trunk lid (ie. dynomat, etc) will cause this.
![]() ![]() Drives: 2008 Yaris Hatch Back Join Date: Feb 2011
You may need to add/replace the Hydrolic (sp?) supports on either side of the trunk.
The sedan uses torsion bars, rather than gas shocks. They are #12 and #13 in the diagram below. They may be too fatigued to support the trunk.
What about adding a spring between 13 and 14? Adding more torsion.
Thank you very much everyone
I'll check out everything that you've posted and i'll get back to you @tk1971 no soundproof @CTScott i will check it out @Tom48 Too complicated |
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris sedan Join Date: Jun 2007
The trunk lid blows down in a breeze on my sedan. It ALWAYS catches me by surprise and is a painful reminder. I would have been happier with gas struts, but that ain't how they built it. The trunk lid is very flimsy, and I ain't sure that it would stand up to struts.
Not many flaws in the Yaris sedan, but that is one of them... |
@TLyttle Yep yep that's true i always get reminded by the trunk that it doesn't stay up because it hit's me everytime
I had taken the spoiler off my EVO (to avoid all the silly stop light challenges) and every time I popped the trunk, it would launch up. That's why either there is extra weight on the trunk, or the tension bars are binding, or they are no longer correctly in place. Good luck.
I agree as torsion bars rarely go bad particularly in this type of application although, it is a pssibility. |
![]() Drives: 2008 toyota vios 1.5G A/T Join Date: Oct 2008
same problem here. thought it was just one of the quirks of the vios/yaris. it would be nice to find a solution to this problem.
#14 |
Joined 3/08 ... really
Ahem, all, may I please direct your attention to the Yaris TSBs thread where I discovered this little gem well after my warranty expired.
To sum it up ... Toyota has known about this issue for a while without telling anyone and we all have bumps on our heads because of it.
#15 |
![]() ![]() Drives: 2009 Toyota Yaris Hatchback Join Date: Jan 2011
I sorta got the same thing on my hatchback, after this winter the trunk does not open on its own I have to push it up. Any Cheap Ideas on what I could do?
"Dat's only in da moning." |
#16 |
@CTScott I changed the torsion bar , i put on the one without spoiler and it's worse now what should i do ?
#17 |
The no spoiler one would provide less tension than the spoiler one. If you read the TSB linked above, supposedly there are newer ones which provide more resistance than the original ones.
#18 |
So what should i do now purchase the one that says with spoiler ?
| Remote trunk opener | Dec24th | Cosmetic Modifications (Exterior/Interior) | 16 | 01-29-2016 10:18 PM |
| Sedan trunk question | brg88tx | General Yaris / Vitz Discussion | 15 | 07-08-2010 03:30 PM |
| Adding Power Trunk Release Ideas...Need Help | Jrilla | DIY / Maintenance / Service | 12 | 08-23-2009 03:38 PM |
| Trunk carpeted and rear seat belts removed (lots of pictures) | m911gt | Cosmetic Modifications (Exterior/Interior) | 24 | 05-24-2009 05:38 PM |
| yaris sedan remote trunk relase question pls help soon | fantabulousbaby | New YARIS Purchase Forum | 4 | 08-05-2006 02:26 AM |
