I ain't even mad
Which fuel do YOU use
And why? I figured this thread has been made but whatever.
91 Octane Premium for me no other crap added.
JOE GIRTH
Drives: YARIS 3DOOR Join Date: Feb 2007
BE PREPARED to be flamed....
I ain't even mad
For remaking the thread? New members do register quite often atm it seems.
For using Premium? Lol, gas prices don't effect me.
#4 | |
USAF_SrA_E-4
It's not that
I ain't even mad
Oh crap.
![]() ![]() Drives: 2010 5 Door Join Date: Jan 2011
![]() ![]() Drives: Yaris sedan Join Date: Jun 2010
I use cheapest regular fuel i can find, why would u use premium?
I ain't even mad
I just use it because I know it is 100 percent gasoline, it bugs me that the other gas has the other corn crap in it. It feels like the vehicle burns the premium quicker but thats about it.
![]() ![]() ![]() Drives: '08 LB, '07 WRX Join Date: Jan 2009
around here all gas is 10% ethanol (corn crap). In response to the question, we run regular in the Yaris (Shell if possible), and I run Shell V-Power in the WRX (and nothing else if I can help it)
#10 | |
I ain't even mad
Have you noticed the wrx will burn quality fuel quicker than ethanol fuel aswell?
![]() ![]() ![]() Drives: 2010 5 door hatch w/5 sp man. Join Date: Jan 2011
I use regular 87 10% ethanol (CT). Premium won't do anything extra for you. My fussiness is that I only use top tier gas which is either Shell or Mobil in my area. I also heard that Chevron is the best but it's not available here.
All of our premium here is 10% ethanol so its the all the same. There is ONE sation I can by non-mixed prem from, but its a ton of money (like $.25 more per gallon)
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
ethanol burns at a 50% less ratio than gasoline. but, it will not detonate in the chamber. so, you're only 95% efficient running any gasoline other than 100% in the US.
second...the rating of octane is not how efficient it is but the burn rate or detonation prevention of the gasoline being used. 87 octane is 87% less likely to detonate at a specific compression than 91 octane which is 91% less likely to detonate. 91 octane burns slower allowing for higher compression or more advanced spark....hence the higher octane rating of performance cars and such. it has NOTHING to do with fuel economy...and actually 93 octane is cheaper to produce than 87. |
#14 |
![]() ![]() Drives: '10 3D Liftback Join Date: Mar 2010
Lower octane burns faster and makes more torque. High perf. engines use higher octane because they have to in order to prevent pre-detonation of the charge. They are still running the lowest octane they can get away with. If you use higher octane than you need, the charge burns slower, so more of it is still burning on the exhaust stroke = more strain on the engine, less power at the wheels, and more of your charge wasted burning in the exhaust manifold.
#15 | |
#16 | |
Ethanol has less BTUs (energy) per gallon than gas so it's less efficient . Here's a chart of energy values for different gas formulations: http://en.wikipedia.org/wiki/Gasoline_gallon_equivalent |
#17 |
#18 |
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 04:34 AM |
| The "let's brainstorm how to make a piggyback work" thread | eTiMaGo | Forced Induction Forum | 83 | 08-17-2011 04:54 PM |
| "5 Driving Myths That Cost You Money" | PETERPOOP | Fuel Economy Forum | 10 | 05-24-2011 11:20 PM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
